01-11-2013, 11:25 AM | #1 |
Rock Stacker Join Date: Dec 2012 Location: burlington
| Need Help
So I have had this problem multiple times and it usually fixes itself. Any time I unhook the electronics from my RTR wraith for an extended period while working on it then hook them back up on the servo will work. No power to the motor no beeping like it is not bound. Can anyone tell me ways to troubleshoot and fix this? I have searched and tried to the best of my noob ability to fix it based on those suggestions without luck. Sent from my DROID RAZR using Tapatalk 2 |
01-11-2013, 01:52 PM | #2 |
| Re: Need Help
Sounds like a loose power wire. It could be the leads from the battery to the ESC or the red wire from the ESC to the receiver. My first suspicion is the loose wire from battery to ESC. I've seen the wires loose where they connect to the ESC inside the case. If it's that you may be able to RMA if it's relatively new. Otherwise, time to pull out the soldering iron and fix it. |
01-11-2013, 08:09 PM | #3 |
Well I was wiggling all the wires and presto acted like nothing happened. I'm still having it act a little jerky when accelerating or when suddenly going from forward to reverse. Sent from my DROID RAZR using Tapatalk 2 |
