01-12-2013, 05:14 PM | #1 |
Pebble Pounder Join Date: Jul 2010 Location: California
| Cobalt Puller Sparking! Timing?
My cobalt puller has just been installed after purchasing it from classifieds. I have seen it sparking when I really punch the throttle or throw it it reverse. I have read theat timing may be the issue that it may have retarded timing but I am not sure how to reset the timing to 0. I need some pictures to guide me. Also, the motor has been running faster in reverse than forward no mater how the power cables are arranged. Thanks Chris Sanchez |
01-12-2013, 05:38 PM | #2 |
Newbie Join Date: Apr 2012 Location: Kingsbury, NY
| Re: Cobalt Puller Sparking! Timing?
Lots of great info here: 540 Brushed Motor Care, Installation, and Troubleshoot | The Search for Power Holmes Hobbies makes quality products at a great price.
01-12-2013, 07:00 PM | #3 |
Chris....some sparking is normal for brushed. As to faster in one direction, assuming the ESC is correctly set up as well as the radio, you likely have timing the wrong way. DaBomb gave a decent link referring to timing. Last edited by Charlie-III; 01-13-2013 at 06:11 AM. Reason: Fix typo |
01-12-2013, 10:36 PM | #4 |
Do you have timing marks on ur puller? I sent pics of my 3 pullers to John just a couple days ago, two are a little diff an one is rotated a good bit. One has timing marks scratched into it. I have yet to hear back from him, it is the weekend... I'm looking for comparisons if you do have marks.. a pic would help me help you more either way.. The two with motor plates are close, one with deans has marks, one without a motor plate is farthest off.. Hope it helps both of us... Brushes spark.. its not just urs.. |
01-13-2013, 03:41 PM | #5 |
My can doesn't have any timing marks but I did find this Caring for your new Brushed motor for the timing issue I had I also know that there are puller motors out there that are not made by holmes but by the same factory that he uses or something like that. |
01-13-2013, 03:43 PM | #6 |
I set my motor to zero timing and It seems to not spark anymore or at least no as violently or often. Thanks for the help guys. This motor is the bomb I love it!
01-16-2013, 02:33 AM | #7 |
Ok, got word from John that 0 timing is 90* in the center of the big opening.. if that's what you found ur good to go. A little delayed..
01-16-2013, 11:54 AM | #8 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
I just go by sound.... Loosen endbell a little go full throttle fwd/rvr back and forth as you make very small adjustment and I call it a day. Definitely not the most accurate but without hash marks its better than just tearing up brushes. Brushes will spark though , it can be excessive though from timing or even wear/debris Last edited by Joshs4x4toyz; 01-16-2013 at 12:01 PM. |
Cobalt Puller Sparking! Timing? - Similar Threads | ||||
7t puller timing? | J-FAB NOR-CAL | Electronics | 2 | 12-29-2011 09:57 PM |
timing advance on a 7t puller? | ebomb | Electronics | 3 | 04-06-2010 02:49 PM |
7T Cobalt Puller...you need one. | miller | Electronics | 19 | 02-21-2008 11:47 AM |
