01-18-2018, 12:28 PM | #141 |
Newbie Join Date: Feb 2017 Location: West chicago
| Re: How to wire LEDs
GREAT tutorial!!! Thank you!!
04-08-2018, 07:36 PM | #142 |
Pebble Pounder Join Date: Jul 2006 Location: Sacramento, Ca
So I found some flashlights I'm gonna cannibalize for the surface mount leds. They're running on 4.5 volts and I'm going to use power from a 3s pack 12v. So using the wizard ,source is 12v , forward voltage is 4.5v? Also how do I figure current? Thanks in advance. Carl
04-09-2018, 08:40 AM | #143 | |
| Re: How to wire LEDs Quote:
Unless the packaging of the flashlight gives you some clue as to the power of the LEDs, you will have to measure the current draw with an ammeter. If you can post a picture of it, I could guess at it, but best is to measure it. | |
04-09-2018, 04:40 PM | #144 |
so to measure the draw I use an ammeter between the led and the supply? I cant seem to post a photo.
04-09-2018, 05:00 PM | #145 |
Type this into google: "how to use a dc ammeter" |
04-09-2018, 05:04 PM | #146 |
| Re: How to wire LEDs |
04-09-2018, 05:10 PM | #147 |
My best guess is that is a 3 watt LED. Put your volt meter on the two white wires on the LED. What is the voltage? This will be the "forward voltage". Then we can find the current using some math because I (assume!) it is 3 watts, using P=IV Transpose that to I=P/V so 3/ your measured forward voltage will give you the current. |
04-09-2018, 05:18 PM | #148 |
The AAA batteries are kinda low. The voltage coming out of the three batts is 3.67 and the two wires at the led show 3.04
04-09-2018, 05:21 PM | #149 |
3 volts is what I would expect. Now do the math to find the current. |
04-09-2018, 05:36 PM | #150 |
Here's the math to find the current through the LED Again, assuming 3 watts of power and we have measured 3 volts across the LED. We can find the current with this formula: Current (amps) = Watts / Volts 3 / 3 = 1 amp Now you can plug that number into your LED calculator. |
04-09-2018, 05:38 PM | #151 |
Lol sorry math isn't my strong suit. I have no idea how to use the equation. So I is the current?
04-09-2018, 05:40 PM | #152 |
Yes. 1 amp is the answer for how much current your LED needs. Your LED calculator might want the current in mA. If it does, you put in 1000mA (same as 1 amp) 3 is the forward voltage of your LED |
04-09-2018, 05:52 PM | #153 |
So if I'm not screwing this up , it needs a 10 ohm 10 watt resistor? Aren't those the huge ceramic kind?
04-09-2018, 05:56 PM | #154 |
Yes, that's what it will take if you run one of those LEDs from 12 volts. There is a cheat that you could do. Connect four of the LEDs in series and run it without a resistor. We can do that because - again, I am making an assumption - you are probably using a 3S lipo for the power. Fully charged is very close to 12 volts and will work just fine. |
04-09-2018, 06:20 PM | #155 |
I only have the two. Any other approach besides resistors? Maybe some kinda diode? Or maybe a step down from a fpv quad. They have some that drop from 12v to 3.3 v. Just not to enthused about the ceramic resistor.
04-09-2018, 06:21 PM | #156 |
Oh ya thanks for all the help. It's much appreciated.
04-09-2018, 06:24 PM | #157 |
You're welcome!
02-28-2020, 08:48 PM | #158 |
Newbie Join Date: Jan 2020 Location: Leamington
An excellent tutorial with some great links. This has helped me out so much with wiring up led's for a couple of projects. Thanks a bunch for the education!
02-29-2020, 05:38 AM | #159 |
10-31-2022, 04:37 PM | #160 |
Newbie Join Date: Mar 2015 Location: Beaver, PA
I see this started back in '13, but 9 years later and it still has great info in it. Thanks for the write up. |
Tags |
led, tutorial, wiring |
How to wire LEDs - Similar Threads | ||||
Wire for LEDs. | Mirage | Electronics | 3 | 03-16-2012 07:59 PM |
Easiest way to wire LEDs in body | AdverseCity | General Crawlers | 3 | 01-22-2012 09:03 PM |
little help with leds please!!! | lordjasper1988 | Losi Micro-Rock Crawler | 5 | 03-09-2011 05:14 PM |
Lipo wire smaller than ESC wire..problem? | solomon7 | Electronics | 3 | 03-27-2008 08:45 PM |
how do I wire red LEDs so it will light up during braking? | ussprinceton2004 | Newbie General | 0 | 03-07-2008 05:33 PM |
