01-13-2013, 05:04 PM | #1 |
RCC Addict Join Date: Jun 2012 Location: Meridian,Id
| servo and bec ?
hello i have a scx10 that i have been running a savox sc-0251mg servo and a castle bec with no issues at all.i just finished installing ridgecrest axles and installed the servo it was moving really fast then turned to one side and wont move now. i checked the bec and it was at 9v before i tore it appart it was set at 6v so i changed it back to 6vand installed a axial servo then it worked for a few min then did the same thing should i move the bec to lower that 6v or would it be my endpoint adjustments.sorry for the book but im frustrated.thank you!
01-13-2013, 09:19 PM | #2 |
| Re: servo and bec ?
9v is over kill. 6v should work. I would check your wiring. Maybe some isn't right.
01-13-2013, 09:28 PM | #3 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
| Re: servo and bec ?
Or a blown BEC....they act real funny when fried
01-13-2013, 09:50 PM | #4 |
| Re: servo and bec ?
i hooked up the castle link and set it to 6v then it fried the next servo i think my end points were at 125% also will that do it .thanks for the help guys
01-13-2013, 10:04 PM | #5 |
| Re: servo and bec ?
Does the BEC light up your Castle Limk??? I mean does it register like it is alive??? I fried one when I fried an FXR. I knew the ESC was gone..But what I didn't know is it took the BEC with it. When I put a new ESC in the rig...the servo started jiggying around like it was way over amped and acted all crazy. Maybe I unplugged it soon enough, I don't know....but replacing the BEC fixed that issue. Good luck man... |
01-13-2013, 10:08 PM | #6 |
| Re: servo and bec ?
yes it popped up on the screen and i moved it to 6v then i checked the voltage later with a volt meter and it read 6 every time.
servo and bec ? - Similar Threads | ||||
Help with CC BEC to servo | 99xjlove | Losi Mini-Rock Crawler | 18 | 04-29-2012 01:37 PM |
Servo and Bec | carp40 | Electronics | 6 | 06-18-2010 03:33 AM |
New servo and BEC? | SukiCrawler | Electronics | 5 | 07-31-2008 06:11 PM |
