01-17-2013, 11:54 PM | #1 |
Pebble Pounder Join Date: Jun 2010 Location: bowling green
| ???? on broken rx wire
So my rx antennae wire wire broke about 3" away from the rx its a traxxas 2.4 5 channel.. my question is can I do anything to fix it don't really wanna buy a new one....thanks for any help
01-18-2013, 06:27 AM | #2 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: ???? on broken rx wire
I think you can buy new ones cheap, since its also 2.4 it means its a simple pop on and off, should not be soldered to the board. I know the Futaba receivers use the connectors on the board. Traxxas SHOULD sell replacements, but sometimes they prefer not to. Found this on an old forum: UPDATE: Replacing the wire on the 2218 2.4ghz link reciever is not only "do-able" by the end user, it is actually one of the easiest things to repair on your RC vehicle. FYI- once you pop the reciever case open with a small flat head screwdriver, the antenna is attached via a small "snap-on" clip. Yep...that's right. You snap the old one off...and snap the new one on....its that easy. Sadly, Traxxas either has no clue or doesn't want you to know. I ended up buying a replacement antenna from Spektrum (2.4ghz 3100 model) for $7 and snapped it on. Now why won't Traxxas sell replacement antennas? My guess is they make more $$ charging $20 for repair than they would $7 selling replacement antennas. :( I'll bet this thread gets yanked in no time flat!:fear: |
01-18-2013, 08:59 AM | #3 |
Thanks for that but I just popped the case and the wire is solder to the bored .... I'm probably just gonna upgrade my radio and stuff anyway thinkin of goin with a flysky.... For what I would pay for a new rx or to even send it in and get it fixed
???? on broken rx wire - Similar Threads | ||||
broken reciever wire | ax10 | Electronics | 3 | 05-13-2012 04:35 AM |
Broken wire...again. | monkeyracing | Losi Micro-Rock Crawler | 5 | 12-10-2010 10:53 PM |
How do I wire? | lud98r | Electronics | 10 | 04-08-2009 06:00 PM |
Lipo wire smaller than ESC wire..problem? | solomon7 | Electronics | 3 | 03-27-2008 08:45 PM |
Broken, wire on mother board. Help! | AfflictedPast | General Crawlers | 8 | 03-09-2007 07:35 PM |
