01-19-2013, 12:55 PM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| few questions on Lipo ratings
I'm still learning about all this. Please bear with me. First lipos I got were sky and gen ace. Seemed pretty good and pretty cheap. I bought an Emaxx that came with lipos too.. 2 smc and 2 thunder power.. The to sky and thunder power have the same ratings. I had the day off so i was messing around a bit. all four batteries are very close to new. The sky lipos did okay. I have used them before. The thunder power batteries. Just touch the throttle the truck flipped onto its top.. There seems to be a good difference in power. Thunder power batteries cost a good bit more. I sure would say it's worth it though. So that's little background. What I'm wondering is how do you know the ratings are accurate on the battery you're buying?? make sense? thanks again |
01-19-2013, 01:27 PM | #2 |
| Re: few questions on Lipo ratings
Same ratings....what ratings?? From your description, sounds like the "C rating" is different. On small packs (lower mah) the "C rating" makes a difference. On larger packs "C rating" is not as much of an issue. Punch is a combination of "C" & mah. When mah goes low, the "C" MUST go high. |
01-19-2013, 01:49 PM | #3 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
^^+1^^ I would think the flipping batteries have a higher C rating than the others which give you a bigger burst rate or off the line power vs a smaller C rating
01-19-2013, 03:58 PM | #4 | |
| Re: few questions on Lipo ratings Quote:
The SMCs I have are so-so, not spectacular, but not worthless either. Heard many other similar comments. Just nice, stable, solid performers, with little flash and fanfare. In my experience, anyways. But I've heard quite a few reports (from both go-fasts and airplane circles), that Thunder Power batteries are renowned for being robust performers when all-out performance is what counts. If I really needed some 'premium' batteries, these'd be on the short list. | |
01-19-2013, 07:30 PM | #5 |
didnt explain very well i guess. all 4 packs are the same 3s and mah. seem the thunder lipos have more punch
01-19-2013, 07:34 PM | #6 |
Quarry Creeper Join Date: Jun 2012 Location: Earth mostly
I used a carbon pile load tester and an amp clamp to test some batteries just for my own curiousity.Traxxas, Hobby people, onyx, Venom, Thunder power, a silver battery with a red label i cant remember the name of and a couple of nameless packs with the labels rubbed off I got used. The thunder power, Traxxas and hobby people I had two identical batteries of each and running them in my summit I felt the Traxxas and Thunder powers were better and lasted longer.This was by no way a scientific test but I wondered if it was true or I just wanted it to be in my mind since they were more expensive than my other batteries. There was a big difference in the brands. The cheapie no names I had dropped way below the others in a load test. the thunder power and Traxxas were the best. That said I paid double for the Traxxas batteries than the Thunder Powers so I don't think there a good value. I only really only notice the difference in my high speed RCs though in my crawlers the junk batteries don't last as long but I don't find a difference in power. Again this is half my own conjecture and a hill billy load test.
01-19-2013, 07:58 PM | #7 | |
| Re: few questions on LiPO ratings Quote:
Are all the packs the same "C" rating?? It won't matter if they're all 3S with the same capacity (mah), the "C" rating also matters, especially on lower mah packs. Even if ALL the specs are the same, "some are more equal than the others". This is part of my issue with MaxAmps. They are 2-3 times the price, but seem to be ~equal on performance. | |
01-19-2013, 08:50 PM | #8 |
forgot that one all 35c
01-19-2013, 10:15 PM | #9 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
I've found that the "C" rating was nothing more than a price whore for some bat manufacturers. They could label it whatever rating they wanted and you wouldn't be able to tell if they were accurate or not. UNLESS you were running a go fast rc...you can definitely tell the difference in "C" ratings then, just by the punch factor. Crawlers don't necessarily concern themselves with burn-outs off the line.
01-20-2013, 03:57 AM | #10 | |
01-20-2013, 05:59 AM | #11 |
Rock Crawler Join Date: Oct 2011 Location: Canada
3s 20c packs are all I will ever need in my SCX-10! In my formula fastech on 4s i need 40c or higher, Thunderpower 70C makes it run cool and fast all day long. I cheap out on the Crawler and spare no expense with the boat. But like the above poster said, Crawling doesn't need much C unless you have a low turn motor, but thats not really crawling then is it.
01-20-2013, 09:57 AM | #12 | |
I run 1350 or 1300 30C rated 3s in comps. Haven't had to do any gap jumping yet, but I have plenty of wheel speed with a 35t HH. I would trust Thunder Power C ratings in general, they are a quality manufacturer... | |
01-20-2013, 03:34 PM | #13 | |
01-20-2013, 05:14 PM | #14 |
Quarry Creeper Join Date: Sep 2012 Location: middle of nowhere
The amps a battery can supply is based on the discharge c value and mAh. A 20c 1000mah (20*1.0=20amps) can produce twice the power as a 20c 500mah battery (20*.5=10 amps). Divide mAh by 1000 and multiply by its discharge rating. I understand not all manf represent their discharge ratings accurately, but as far as plugging in the numbers this is how you figure it. Sent from my iPhone using autocorrect |
few questions on Lipo ratings - Similar Threads | ||||
Lipo Questions!! | brockly242 | Electronics | 7 | 03-20-2011 11:37 AM |
Lipo questions | Chevdog | Electronics | 23 | 02-17-2011 11:59 PM |
lipo ratings | spgrading | Newbie General | 4 | 12-26-2009 12:32 PM |
another lipo question about c ratings | Dubs Chops | Electronics | 18 | 03-20-2009 02:27 PM |
lipo and lipo charger questions | OldShovelhead | Electronics | 9 | 07-11-2008 11:06 PM |
