01-20-2013, 01:25 PM | #1 |
Rock Stacker Join Date: Jan 2011 Location: Sun Valley
| Weak motor?
Weak motor Ok so I have a rooster crawler esc with a Novak 45 t rockstar motor. When I get in a little bind it seems like the motor gets weak. It also gets really hot. No idea what's up. I do have a bec hooked up as well. Any help would be awesome!! The motor hasn't been used often and I do have a cc bec hooked up |
01-20-2013, 01:28 PM | #2 |
Pebble Pounder Join Date: Dec 2008 Location: kingsland
| Re: Weak motor?
how dose the motor brushes look? and what pinon gear are you running
01-20-2013, 01:32 PM | #3 |
| Re: Weak motor?
Brushes are good and shiny and pinion is stock axial gearing
01-20-2013, 02:00 PM | #4 |
| Re: Weak motor?
0n mine im running a 16 pinon never had it hot , all i can say is clean the com where the brushes ride and you might think of a brush change if one gets a small crack or hangs up they do that
01-21-2013, 02:16 PM | #5 |
| Re: Weak motor?
rebuilt the motor last night and still having the issue.
01-21-2013, 04:30 PM | #6 |
| Re: Weak motor? |
01-21-2013, 06:58 PM | #7 |
| Re: Weak motor?
I polished the armature an checked the brushes. Brushes were good. Like I said I haven't run the motor much.
01-22-2013, 02:37 AM | #8 | |
| Re: Weak motor? Quote:
In an electric motor torque and current goes hand in hand. In a bind/stall the motor will draw its maximum current from the battery (limited only by the combined resistance in wiring, ESC and battery). The power drawn is all converted into heat, since there's no mechanical power delivered. This makes the motor heat up. As the motor heats up, the wiring's electrical resistance goes up as well, increasing the heat generated while slightly reducung current and torque. The solutions are to a) use a smaller pinion to get into binds less often. b) use a slipper clutch. (I don't.) c) once you get into a bind, release the throttle ASAP to prevent overheating. Free the crawler by hand. If you keep the motor powered while being bound up it will overheat. | |
01-22-2013, 06:06 AM | #9 |
| Re: Weak motor?
Makes perfect sense. My only concern is that I could be a cold motor and fresh battery and it still happens. I'll try the small pinion tho. Thanks for the info
01-23-2013, 12:15 AM | #10 | |
It's the bind that (indirectly) cause the heating, not the other way around. | |
01-23-2013, 11:23 AM | #11 |
| Re: Weak motor?
Agree but when I take my stock scx10 and I have no issues that makes me wonder its something else other than my driving.
Weak motor? - Similar Threads | ||||
weak link | NickGood | Newbie General | 12 | 02-01-2011 10:22 AM |
BEC too weak!! | jeepster73 | Electronics | 2 | 03-23-2009 03:35 PM |
FX-R weak reverse???? | racerx | Electronics | 30 | 03-06-2009 06:50 PM |
Not For The Weak | ROCKEDUP RICKY | Kansas | 2 | 05-16-2008 02:24 PM |
Front motor weak and boggy | Trike Kid | General Crawlers | 6 | 11-04-2005 11:11 AM |
