01-21-2013, 11:19 AM | #1 |
Newbie Join Date: Dec 2012 Location: Paducah Ky.. / Western KY.
| Scx10 problems(cutting out)
I bought a new RTR scx10 honcho, I love it by all means . Bt I've have some trouble with it cutting out . With a fulling charged 7.2 Nimh battery it cuts out alot. Mostly when it's under a load like trying to climb or if I go from forward to reverse to fast, I'm not sure if this a actually problem with it or if its a low battery etc. the battery is new less then a month old , and not only does it with one battery but all 6 that I have .. Any help? Tips? Ideas?. Side note , not sure if this could be it but I did some waterproofing using the ballon method recommended by axial. Not sure if it a heat issue with the ecs. Other than under a load it runs strong just when I try to take off fast . It's almost like I have to ease into the throttle.. Ad I have replaced battery in remote with new lithium batteries thinking that maybe the problem as well.. No change. Thanks in advance.. |
01-21-2013, 11:52 AM | #2 |
Rock Crawler Join Date: Nov 2011 Location: Paradise, ca
| Re: Scx10 problems(cutting out)
Try reprogramming the esc with a castle link
01-21-2013, 11:57 AM | #3 |
I've thought about that as well, guess ill go ahead and order one lol.
01-21-2013, 12:09 PM | #4 |
RCC Addict Join Date: Dec 2006 Location: Oak Ridge, TN
Make sure the LVC for lipos is turned off. When you dump the throttle it could trip the LVC if it's on.
01-21-2013, 12:51 PM | #5 |
Rock Crawler Join Date: Oct 2011 Location: Warren
My dad had the same problem with his wraith. It is most likely your low voltage cut off. The come from the factory programmed for lipo. When you get on it hard with a nimh they cut out.
01-21-2013, 02:19 PM | #6 |
This might be a dumb question but how do I turn of the LVC?
01-21-2013, 02:34 PM | #8 |
Thanks, ill see how this works
Scx10 problems(cutting out) - Similar Threads | ||||
scx10 driveshaft problems | TNBiscuit83 | Axial SCX-10 | 21 | 06-27-2013 09:33 PM |
scx10 problems | Bronco2x84 | Axial SCX-10 | 3 | 01-10-2013 05:22 PM |
SCX10 kit problems | AG74683 | Newbie General | 28 | 09-06-2011 07:28 AM |
scx10 problems???? | dunwoody | Axial SCX-10 | 1 | 05-18-2011 05:44 PM |
cutting the foams for tires w/ scx10 kit?? | yellowpasta2000 | Axial SCX-10 | 4 | 12-09-2009 05:37 PM |
