Thread: 3s on a sidewinder?
Old 01-22-2013, 11:51 AM   #1
I joined the Band!
Default 3s on a sidewinder?
Hi all. I have a quick question. Can I safely run some small 3s 1000mah 35c batteries on my scaler? It has an original sidewinder with a 6v bec wired in. 55t axial throw away motor. And a 7955 tg hitec. Also any idea of " crawling " runtimes? Geared 87/20..1.9 ttc claws. Thanks in advance guys
TNCrawler is offline   Reply With Quote
Old 01-22-2013, 11:53 AM   #2
Suck it up!
Duuuuuuuude's Avatar
Default Re: 3s on a sidewinder?
Yes, they'll handle 3s just fine. Run times depend on how heavy your trigger finger is.
Duuuuuuuude is offline   Reply With Quote
Old 01-22-2013, 11:56 AM   #3
I joined the Band!
I'm more of a slow technical style crawler. No southern buggy style driving here...
Old 01-22-2013, 11:57 AM   #4
Suck it up!
15-20 minutes maybe. Why so small of a battery?
Old 01-22-2013, 12:00 PM   #5
I joined the Band!
They were practically free.....lol. I was gonna try the rig on 3s to see how it handles before I dropped the coin on some larger mah batts. I have a butt ton of 2s. I just figured it would have more grunt with the 3s
Old 01-22-2013, 12:14 PM   #6
I run Sidewinder SCT's on 3S in my XR10 and it's good. I do use an external BEC though. The internal BEC isn't too powerful on 2S and on 3S it's really only good enough to power the RX. You should be fine for a while, but keep an eye on things and if you start to get brown outs then may be time for a BEC. I also have 2 V1 Sidewinders sitting on my bench (from Castle garage sale) and I'm trying to decide what to put them in.
ik632 is offline   Reply With Quote
Old 01-22-2013, 12:16 PM   #7
I joined the Band!
I have an external bec wired in already. So I should be good to go...?
3s on a sidewinder? - Similar Threads
sidewinder and sidewinder SCT troubleshooting nstn8 Electronics 7 01-17-2011 07:50 PM
sidewinder with a cc bec,works great but Can I swap it out for a Micro sidewinder? username Electronics 3 04-04-2009 10:11 PM
sidewinder/sidewinder micro/mamba 25 nj05nismo Electronics 2 03-07-2008 08:42 PM
