01-22-2013, 01:44 PM | #1 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
| Anyone running onboard solar lipo charger?
I had a thought of maybe 2 lipo packs with a solar panel charging one while running the other for motor power, when the power pack gets dischaged to the cutoff point the circut switches the packs (charging the disharged pack & running the motor on the charged pack.) I searched a bit & found nothing. Anyone out ther working on something like this? |
01-22-2013, 01:48 PM | #2 |
Quarry Creeper Join Date: Dec 2012 Location: Spokane Valley
| Re: Anyone running onboard solar lipo charger?
Sounds interesting, but I don't think a tiny solar panel would provide enough power to charge the other battery quick enough. You'd also need a balancer...
01-22-2013, 01:53 PM | #3 |
Yes I assume a balancer & a contoller of some type to keep track & switch the packs at the right voltage. Seeking a hands on "I did that" for their opinion based on experience & facts. |
01-22-2013, 01:55 PM | #4 |
RCC Addict Join Date: May 2011 Location: Utah County
Would be sweet. Sounds like more money/work than its worth when you could simply buy one more battery. With 3 you could easily have one on the charger while your driving and as soon as that one is dead your other is charged. Etc. And besides a quick battery swap you don't have to stop playing. Which is what the solar system is trying to accomplish. Sent from my SCH-I535 using Tapatalk 2 |
01-22-2013, 02:03 PM | #5 | |
| Re: Anyone running onboard solar lipo charger? Quote:
01-23-2013, 12:20 AM | #6 |
Size and weight makes it a non starter for a comp rig. Looks makes it less suitable for a typical scaler. If I wanted solar power and a somewhat kosher look I'd put it in the trailer of a scale 18-wheeler. |
01-23-2013, 01:56 AM | #7 |
Quarry Creeper Join Date: Oct 2012 Location: Canada
If you consider that you drain a 5000 mAh 2S battery in 1h30min, which is plausible in a scale RC, you have a power consumption of around 26w per hour. If we go fast on the math, you will need a 30W solar panel to keep with the electrical draw. And a 30W solar panel is roughly 16"x 26" |
01-23-2013, 05:54 AM | #8 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
| Re: Anyone running onboard solar lipo charger? |
01-23-2013, 06:22 AM | #9 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
One o our guys has been looking at this but more just to power lights and extras. Not really sure how but I will tell him to come stick his head in here.
01-23-2013, 06:28 AM | #10 |
RCC Addict Join Date: Jun 2011 Location: Gilbert, AZ
Interesting, but as said, the solar technology isn't going to let it happen. You might be able to power a charger with a solar panel but still not going get you to the hands off method you are looking for. You could just run two batteries in parallel and that should get you most of the day. I run around 4 hours on 3 2650mah 2s batts. so I would think 2 5000mah batteries would make for a long day on the trail.
01-23-2013, 08:51 AM | #11 | |
Not intended for a scaler or comp rig more of a special project. I will need to get a panel to do some testing in my area & go from there. | |
01-23-2013, 10:33 AM | #12 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
i can run like 4 hours on my 6000Mah 2s and around 3.5 on my 5000 mah 3s....the capacities are so high anymore that i just don't see the need. Either I or a component give out before the batteries ever do, carry a small capacity unit in case i do run out on the trail. and batteries are cheaper then this setup would be. Not dogging the idea, just pointing out the facts. now for lights and such, might work....
01-23-2013, 10:45 AM | #13 |
I understand that I could put 20k mah worth of 2s lipos in paralell in my wraith & run for hours. I am trying to conceive a vehicle that can run 24/7 for a few days at a time without touching the rig. It seems most of the responses miss that. I am looking for someone that builds robots or specialty rc vehicles, any on here? |
01-23-2013, 10:56 AM | #14 |
Moderator Join Date: Jan 2004 Location: chicago
24/7 FOR A FEW DAYS AT A TIME? |
01-23-2013, 11:01 AM | #15 |
01-23-2013, 11:19 AM | #16 |
01-23-2013, 11:44 AM | #17 | |
I am as well looking for off & on motor use, it will likely sit for long periods then move a while. Think lion folowing a herd of zebras. The key points are reliability,stability, & launch & pickup days later (trust me battery changes or field fixes will not be an option.) At this point its a hair brained maybe a friend with money has proposed. I am looking into how close he might get to his goal. Duuuuuuuuude do you know of any robot/specialty rc land vehicle forums? | |
01-23-2013, 12:11 PM | #18 |
What are you trying to use this in?
01-23-2013, 12:24 PM | #19 |
Quarry Creeper Join Date: Oct 2012 Location: high desert CA.
i like were your head is at iv actually had the same thought,, like someone stated above the size of the solar board needed is pretty big i have been trying to build a closed in trailer like a toy hauler styler that i can house all my electronics in,, im thinking i need to run a capacitor inside the trailer to help hold some voltage,, iv been talking to some guys that build drones, and they said it can be done but if its worth it is the problem,, im going to continue to work on it and if it means i need to make everything bigger say a 1/5th scale scaler thats what ill do,, i was also told that you can dismantle smaller solar panles and wire them in siries and it will increase the amount of voltage going into whatever you are charging, but i havent tried this
01-23-2013, 12:34 PM | #20 |
| Re: Anyone running onboard solar lipo charger? I am as well looking for off & on motor use, it will likely sit for long periods then move a while. Think lion folowing a herd of zebras. The key points are reliability,stability, & launch & pickup days later (trust me battery changes or field fixes will not be an option.) At this point its a hair brained maybe a friend with money has proposed. I am looking into how close he might get to his goal. A Radio controlled electric off road vehicle (custom platform) |
Anyone running onboard solar lipo charger? - Similar Threads | ||||
Replacing fan in lipo charger - Venom Pro Charger | iamsuperbleeder | Electronics | 11 | 04-04-2012 08:06 PM |
