01-24-2013, 08:31 PM | #1 |
Rock Stacker Join Date: Dec 2012 Location: albany
| lipo charger ?
I did a bit of reading and still have a couple of questions. What is the advantage of chargers that require a separate power supply versus one that has a built in one? Are chargers that service all battery types less stable versus a lipo only charger or a nimh/nicd only type charger? i have a very old mrc superbrain. its a red light blinks kinda charger . i have not used it in awhile and only really charged a 1500 pak for the starter hpi supplies for thier nitro engines. i used this charger on a venom power 5000 mah nimh battery i purchased at my lhs and put it in my wraith and found the run time pretty disappointing . maybe 15 mins? The directions the hobby shop gave me where plug in the battery run it till its dead and charge it again and due to the wraiths crawler style speed i should get 40 mins out of the pack. i gave them a buzz and they then told me to charge the battery until light goes off. unplug battery and charger , plug both back in and repeat this process till battery feels warm. Does that make sense? Sound like sound advice? I plan of getting a new charger and batteries but would like to continue with nimh when im goofing off with my son and a lipo for when he grants me an hour or two of free time to goof off myself any advice ,help or clarification would be huge! thanks again!! |
01-25-2013, 01:41 AM | #2 |
Quarry Creeper Join Date: Sep 2012 Location: middle of nowhere
The world of chargers is one full of options and even more opinions. It all depends on what kind and size of batteries you have and also what kind and size of batteries you think you might get down the road. RCs come and go but if your in the hobby for the long haul might as well get a good charger now...based on what you can/want to spend. Features I'd look for is: 1- multi chemistry 2- storage feature (charges lipos to 3.85v ish and stops) 3-discharge is nice but not fully necesary 4- ability to charge more than one at a time I personally have an onyx245 and a powerlab6. The onyx245 is good because its like 2 chargers in one case. It can charge 2 different chemistries, voltages and sizes at the same time. It is only rated to 3s though. It has a port to charge rx batteries for nitros and comes with deans, traxxas, and the old school white tamiya (I think...it's the plug for a traxxas EZ start batt) adapters. It comes with the balance boards for lipos. It has an internal power supply, and aligator clips to run from your car battery if out and about. It does not have discharge or storage features but that can be overcome. It also times out after 90mins so if you plan on getting batteries larger than 5000mah it could time out before a charge is complete...not a big deal just more of an FYI...you just have to restart it. Overal I'm happy with it, it's simple to use and hasn't let me down yet...it's just too small for my other charging needs. My powerlab6...is excessive for most crawler applications and requires a little more battery understanding. It doesn't come with any adapters and needs an external power supply. Nice features include storage feature and the ability to discharge. I can monitor IR of each cell and it has PC interface that allows me to create in depth presets for common batteries I charge. It's high amperage capabilities means in theory I should be able to parallel charge 6 2S 6000mah lipos at once (1C) but I haven't tried it yet... Of the 2 chargers I have I'd recomend the onyx first from the info you've given thus far. Not saying its the best but it would be the more logical of the 2 I have. Sent from my iPhone using autocorrect |
01-25-2013, 04:36 AM | #3 | |
| Re: lipo charger ? Quote:
01-26-2013, 05:35 PM | #4 |
| Re: lipo charger ?
Thank you both for your replies. Im looking into the chargers mentioned .
02-03-2013, 08:05 AM | #5 |
| Re: lipo charger ?
I followed the hs recommendation of restarting the charger . I did it 5 times and the 5000 mah battery worked much better . Run time was amazing . with these nimh batteries when they no longer move the wraith on the ground is it time to charge or should i let it run off the ground until the wheel stop completely ?
02-03-2013, 09:10 AM | #6 |
| Re: lipo charger ?
To be quite honest, you really shouldn't even run it down that far. Check up and stop running a little sooner in the future. While, yes, NiMhs can handle being run clear down like that and won't destabilize like a LiPo, you're still doing some internal damage. I'm not saying stop after only three minutes, but I'd recommend stopping before it won't move. And running the battery out w/ the truck up in the air absolutely will do permanent irreparable damage to the battery, and also you stand to increase the potential for wear and damage on your truck too. |
02-03-2013, 02:41 PM | #7 |
| Re: lipo charger ?
sweet thank you for the reply ! alot different then nitro but i find i can use this truck a lot more often . Cant wait to try lipo seems people find it to be a religious experience .
lipo charger ? - Similar Threads | ||||
Replacing fan in lipo charger - Venom Pro Charger | iamsuperbleeder | Electronics | 11 | 04-04-2012 08:06 PM |
