Thread: XD6i and AR6210 setup / mixing for two ESC.
Old 01-25-2013, 03:22 AM   #1
Default XD6i and AR6210 setup / mixing for two ESC.
Hello,
I'm from Denmark, sorry if my English writing isn't that good
I see you have a lot of knowledge on this forum in programming and setup of the DX6i, hope you can help me.
I have built a catamaran boat with a jet / ESC / motor on each side for move it forward.
The boat must be controlled by slowing down the right engine if you will turn right and slowing down the left engine if you will turn left.
Is it possible to program the DX6i so left stik / throttle is controls the two ESC synchro, and if I operate the right stik to the rigth it brakes the right engine / ESC down.
Hope my explanation makes sense
In advance many thanks for your help
Kuno is offline   Reply With Quote
XD6i and AR6210 setup / mixing for two ESC. - Similar Threads
Flysky GT3B Modded for 3-8 channels, Dual Esc & 4WS Mixing, Plus More losikid Vendors Electronics 28 01-03-2017 03:30 PM
Dual Esc Adapter-Dig, mixing, biasing, for MOST 3CH RADIOS losikid Vendors Electronics 146 03-10-2014 08:30 AM
How to get rear move reverse before front DUAL ESC DX6i Need a Dx6i mixing Guru toy4crawlin Electronics 6 10-26-2011 11:55 AM
Mixing Channels on stock ESC..? slimeball Axial AX-10 Scorpion 0 08-16-2009 11:01 AM
