01-25-2013, 09:09 PM | #1 |
Quarry Creeper Join Date: Feb 2010 Location: Farmington
| 4pl binding problem.
Hey so I'm trying to bind the 4pl to the R2104GF. I'm having a problem with the receiver blinking red. I press the button and it still will not bind. Any suggestions?
01-25-2013, 09:21 PM | #2 |
Quarry Creeper Join Date: Dec 2011 Location: Doylestown
| Re: 4pl binding problem.
Are your throttle trims centered before you calibrate the radio to the ESC?
01-25-2013, 09:26 PM | #3 |
Yes they are centered/0
01-25-2013, 09:33 PM | #4 |
Hmmm weird. Silly question but did you calibrate the RX to the ESC? Or is that what u r trying to do?
01-25-2013, 09:38 PM | #5 |
I'm trying to get the reciever to be recognized by the remote. I keep getting a flashing red light.
01-25-2013, 09:44 PM | #6 |
Check this thread out....one dude had luck by actually binding with receiver and transmitter antenna like inches away or touching. Futaba receiver linking problem :( - R/C Tech Forums |
01-25-2013, 10:08 PM | #7 |
Thank you got it bound but now I cann't get it to talk to the motors or steering using Mamba Micros for the ESC's
01-26-2013, 12:29 AM | #8 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
Do you have them plugged in the correct way
01-26-2013, 09:23 AM | #9 | |
| Re: 4pl binding problem. Quote:
There are 2 RX modes, if you're using the wrong one it will have issues. The ESC's should work the steering even if the motor won't run until the ESC's are calibrated to the RX. | |
02-07-2013, 10:36 PM | #10 |
Pebble Pounder Join Date: Jan 2010 Location: Emmett, ID
Thanks for the info on the thread. Helped a lot. |
4pl binding problem. - Similar Threads | ||||
dig binding problem | Evil_s10 | Axial Wraith | 8 | 08-18-2012 09:48 AM |
binding problem! | crfrider250 | Team Losi Comp Crawler | 30 | 07-23-2012 09:11 PM |
DX3.0 Binding Problem | Dillpickle | Electronics | 9 | 03-26-2011 02:17 AM |
Dx3r binding problem | infamouse_1 | Electronics | 6 | 03-07-2010 05:03 AM |
Do I have a binding problem? | theadrick | Losi Micro-Rock Crawler | 3 | 01-03-2010 02:39 PM |
