01-31-2013, 04:26 PM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| servo shot or esc problem?
i have a scx 10 crew cab with a original sidewinder, 55 turn novak motor a cs 170 servo. turn right under full power not problems. turn left under full power truck slows down for some reason. everything is clean. hooked up how it should be.. any ideas thanks
01-31-2013, 04:40 PM | #2 |
Rock Crawler Join Date: Jul 2011 Location: USA
| Re: servo shot or esc problem?
that is certainly strange........ Are you running a BEC? |
02-01-2013, 09:29 AM | #3 |
no however. they seem mandatory on a crawler.. its in the mail
02-01-2013, 05:35 PM | #4 |
Check your steering EPA's? You may be binding the steering linkage and overdrawing the internal BEC causing a RX brownout.
02-01-2013, 10:34 PM | #5 |
Rock Crawler Join Date: Feb 2011 Location: s. terra firma
Could be what Charlie 3 is sayin. Try to find a hitech servo tester. They can test them in or out of the car. But not under load? Or you may have to just swap out known good parts I have a wraith that had a glitch problem. Wheels shuttered slow speeds, it didn't do it all the time. I swapped out electronics till I figured it out. Servo was overpowered. Bec fixed it it works great now. Don't loose interest and you will figure it out. Good luck. |
02-01-2013, 11:21 PM | #6 |
Rock Stacker Join Date: Nov 2012 Location: Shawnee
I had this problem on my scx... adjusted the endpoint for the side it was turning to and slowing down.. fixed the problem and didnt lose any steering, hope this helps
04-17-2013, 12:37 PM | #7 |
thanks. end points seem fine.. i adjust it more going to lose steering. i realized that i run 2s no problem. i run 3s that when it happens.. didnt put the bec on there yet. maybe thats it
04-19-2013, 10:50 AM | #8 |
could it be i done have the bec in yet?
04-19-2013, 03:08 PM | #9 |
| Re: servo shot or esc problem? |
04-20-2013, 06:14 AM | #10 |
not even close. 106oz at 4.8v and 133oz at 6v... its a tower ts-70 servo thanks
servo shot or esc problem? - Similar Threads | ||||
esc or servo problem | fraze | Losi Micro-Rock Crawler | 7 | 04-14-2012 08:43 AM |
is it my servo or esc problem | bro_die | Electronics | 8 | 12-01-2011 04:43 PM |
Full Sized Servo + Stock ESC = Problem? | rctoyguy | Losi Mini-Rock Crawler | 8 | 01-06-2010 01:31 PM |
weird problem w/ esc, servo, receiver? | jamison31 | Electronics | 11 | 05-18-2009 12:55 PM |
esc/servo problem ?? | kaaina | Electronics | 15 | 09-05-2005 03:25 AM |
