02-01-2013, 04:40 PM | #1 |
Newbie Join Date: Dec 2012 Location: Glenside
| easy to answer motor question
I bought the Novak eiger/rockstar package. You have to solder the wires on the motor which I am ok with. The dumb question I have is that the Eiger ESC has blue and yellow wires (which are defined as + and -) but the motor has red and black sides that aren't defined. The 1:1 mechanic in me says that red is + but I am not sure. What say the smart people here?
02-01-2013, 06:10 PM | #2 |
In my opinion with brushed motors it doesnt really matter what color is what as long as when you give it forward throttle it goes forward. Usually I try to make it so the red is + like it normally is Sent from my SCH-R530U using Tapatalk 2 |
02-01-2013, 07:12 PM | #3 |
Quarry Creeper Join Date: Feb 2008 Location: US
| Re: easy to answer motor question
I agree with benoj. The only thing polarity will affect with a brushed motor is the direction it turns. That is why i've switched to bullet connectors for the motors, because it's easy to rev polarity if you want. Now keep in mind if you have timing set in your brushed motor you don't want to run the motor backwards (turning same direction as the timing) to make the truck move forward or it'll cook it. If it's a new motor, it likely will have zero timing and thus be a non-issue. |
02-01-2013, 07:46 PM | #4 |
Pebble Pounder Join Date: Dec 2008 Location: kingsland
they are wright but if you want to know the yellow is + and the blue is - and the motor the red is + and black is - now if the motor runs backwards flip the swich in your radio from norn to rev or vis versa
02-01-2013, 08:06 PM | #5 |
thanks everyone. Should be running by morning.
02-02-2013, 07:05 PM | #6 |
Pebble Pounder Join Date: May 2011 Location: Da Springs
there should be a plus sign on the positve side of the motor. when you hold it, shaft down, look on top.
easy to answer motor question - Similar Threads | ||||
dumb question but most likely know the answer... | arcanecrawler89 | Axial SCX-10 | 16 | 10-19-2012 06:30 PM |
question and would like an answer | icemancrawler | Newbie General | 4 | 07-07-2010 11:34 AM |
stupid question but need an answer | ziz | General Crawlers | 4 | 09-18-2007 05:15 PM |
Answer me a stupid question... | teamtom | Newbie General | 6 | 12-02-2006 07:52 AM |
easy question just need some one to answer it ... | Rider385 | Newbie General | 7 | 09-09-2006 10:11 AM |
