02-02-2013, 07:23 PM | #1 |
Quarry Creeper Join Date: Dec 2011 Location: poplar blufff,mo
| losi sensored 13.5t esc wont move motor.
it will calibrate to my dxc3 with the red green and yellow leds. its hooked up to a 13.5t novak ballistic crawler. 2s lipo 25c hobbico 170 servo with a novak 5 amp bec. all was fine a day ago replace motor wire today and nothing? my connectors are touching there is no solder dripped anywhere? is this motor dead? i get no sounds nothing from the motor no heat nothing
02-02-2013, 07:25 PM | #2 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
Take a volt Meter and measure A, and B
02-03-2013, 07:01 AM | #3 |
Quarry Creeper Join Date: Feb 2008 Location: US
| Re: losi sensored 13.5t esc wont move motor.
Are you sure the ESC is set to sensored brushless? I know with the MMP if you try to run a brushed motor in brushless setting or vice versa, it doesn't work. It sounds like you had it set up and working before though. |
02-03-2013, 08:11 AM | #4 |
i dont tink this has a brushed setting . it says nothing about it in the manuel. it lets me set my throttle fwd and reverse but it wont finish the calibartion. when i hooked up the other day it wasnt in the rig or attached the tranny i was checking my solder joint and i didnt have to calibrate it at all it just worked? im lost
02-03-2013, 08:35 AM | #5 |
SOLVED there was a stray wire from b hitting c on the motor dumb dumb dumb dumb.....
losi sensored 13.5t esc wont move motor. - Similar Threads | ||||
my ridgecrest wont move | ridgecrest78 | Axial AX10 2nd-gen | 1 | 11-24-2012 09:09 AM |
Losi Xcelorin Sensored ESC/Motor Combo for the MRC! | JatoTheRipper | Losi Mini-Rock Crawler | 123 | 05-27-2010 08:48 AM |
steers but wont move????? | rubiweeler | Losi Mini-Rock Crawler | 13 | 12-27-2008 09:54 AM |
Sensored Motor and NON Sensored ESC. | Timmahh | Electronics | 7 | 12-11-2008 09:21 PM |
