02-03-2013, 10:05 AM | #1 |
Quarry Creeper Join Date: Oct 2010 Location: Saint-Nicolas (qc) Canada
| Cogging with MMP 13.5 Tekin
Hello, I have a MMP with 13.5T Tekin Redline. What is your MMP parameter? I have a lot of cogging... I run it with 3S full charge Lipo and Sensors is plug. I need help! |
02-03-2013, 10:23 AM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
| Re: Cogging with MMP 13.5 Tekin
It shouldn't cog unless your sensor lead is no good or it is set to brushed mode. Have you tried it with the sensor lead unplugged to see if it does the same thing connected and disconnected? The default setting in the MMP will work about the only thing I would change is to set it to Sensored Only instead of Smart Sense and make sure Start Power is set to Low (default). |
02-03-2013, 10:43 AM | #3 |
I recently had trouble with the same motor / esc combination. I took out the motor to do some cleaning around the tranny. When I plugged the motor back in, I mixed up the A B C order of the wires. Thought I broke something! Probably not the same trouble that you are having, but thought I would put it out there just in case. |
02-03-2013, 02:48 PM | #4 |
Double check that you're in smart sense mode, sensor cable is plugged in, and you have ABC matched properly.
02-03-2013, 02:59 PM | #5 |
Rock Crawler Join Date: Dec 2009 Location: Redding
Gearing??
02-03-2013, 03:19 PM | #6 |
Pebble Pounder Join Date: Jan 2010 Location: CA
Turn the timing on the motor down to 0. This helped a bunch for my setup. I set my mmp to sensored mode and made sure the sensor cable was plugged in all the way.
02-03-2013, 03:19 PM | #7 |
Pebble Pounder Join Date: May 2011 Location: under a bridge
02-03-2013, 09:37 PM | #8 |
Thank you everybody! I found my problem. My A,B,C didn't was a good match... It's run perfect!
02-03-2013, 10:11 PM | #9 | |
Rock Crawler Join Date: Oct 2009 Location: Knoxville
| Re: Cogging with MMP 13.5 Tekin Quote:
Yes, I then flew the moron flag. Agreed, it probably not the case, it was a horrible sound. The thing that kept throwing me off was it was running ok at higher RPMs, but down low sounded like gears stripping. You have probably already checked, but it is an easy thing to do. Even for those of us that have taken dozens of motors out. Edit: Sorry, just ready your post above. Excellent, glad you got it figured it out. Last edited by dentonmac; 02-03-2013 at 10:14 PM. | |
Cogging with MMP 13.5 Tekin - Similar Threads | ||||
cogging with tekin 13.5t? | SwampDawg | Axial Wraith | 15 | 09-25-2012 04:18 PM |
New Tekin 13.5 cogging? | lkracer | Axial Wraith | 12 | 08-16-2012 08:16 PM |
Tekin 13.5 just cogging or bad MMP? | Checkitout0125 | Electronics | 11 | 01-17-2012 07:28 AM |
New MMP 1c and some low end cogging | concretejungle | Electronics | 31 | 02-27-2011 09:47 AM |
