02-03-2013, 11:55 AM | #1 |
RCC Addict Join Date: Oct 2008 Location: south caki laki again
| This one is nuts
Bec set @ 7.4 volts Futaba 6114ff receiver Futaba 4pks Red and black wires going into bec power supplied by external battery (charged) connector side of BEC red wire goes to red on 7950 servo black to black, tan wire (signal) plugged into receiver, It does not work?? tried 3 bec's all good, tried 3 receiver's, all good tried 2 servo's, all good I have this exact same set up on both comp crawlers and my jeep and it worls fine. Help |
02-03-2013, 12:05 PM | #2 |
| Re: This one is nuts
OK, you say it does not work, but then you state in 3 tests all are "good". I'm not following. In the rig in question, did you try just plugging the servo into the RX? This would make sure the TX, RX & servo are all good in the rig. Then unplug the servo from the RX & set back up on the external BEC, try again. Sorry If I'm not understanding your issue. |
02-03-2013, 12:10 PM | #3 |
everything is testing fine, will not work when combined in this rig, If I remove bec and plug the power wires of the servo into the rec everything works fine?
02-03-2013, 12:23 PM | #4 |
Hoof Hearted? Join Date: Nov 2009 Location: Chattanooga
Hey Joe, just curious why you're hardwiring the servo when that rx can handle 7.4 volts?
02-03-2013, 12:30 PM | #5 |
Its on ellie mae and with the rear steer it gets a touch heated? Figured i would run the front off of ext bec and fix it that way.
02-03-2013, 12:38 PM | #6 |
Makes sense now.
02-03-2013, 02:19 PM | #7 | |
| Re: This one is nuts Quote:
Or do you mean to say the servo's yellow wire going into the receiver? You're black to black BEC to servo, do you also have a black going into the receiver? Last edited by Trubble; 02-03-2013 at 02:25 PM. Reason: red was too hard to read, IMO | |
02-03-2013, 02:33 PM | #8 |
| Re: This one is nuts |
02-03-2013, 02:50 PM | #9 |
Is it wired like this: An Axial Crawler Blog - Get Your Wraith On It sounds like you're missing the ground to the servo. |
02-03-2013, 03:40 PM | #10 | |
It's a Futaba, not normally an issue. If it was an issue, it's usually a glitch, not a "it won't work". | |
02-03-2013, 04:11 PM | #11 | |
02-03-2013, 04:21 PM | #12 |
I wanna be Dave Join Date: Feb 2011 Location: Atlanta, GA
For a hitec servo, shouldn't the yellow wire be the only wire plugged into the receiver (if its hardwired to the BEC)?
02-03-2013, 04:32 PM | #13 |
The yellow wire from the hitec servo should be the wire plugged to the RX. The BEC gets its power from the battery, then (the BEC) hard wires to the servo to give the (servo) power. The yellow wire from the servo, gets signal from the RX. So the tan wire is void? I don't like hard wiring my servos and BECs. |
02-03-2013, 04:35 PM | #14 | |||
02-03-2013, 04:39 PM | #15 | ||
02-03-2013, 04:41 PM | #16 |
It still doesn't work?
02-03-2013, 04:42 PM | #17 |
I looked at an old BEC I had laying on my bench. The tan and red were used, orange cut short. This is jogging my brain... |
02-03-2013, 04:56 PM | #18 |
But it works on both comp rigs.
02-03-2013, 05:00 PM | #19 |
Weird
02-04-2013, 12:21 PM | #20 |
Quarry Creeper Join Date: Dec 2008 Location: Australia
Does it work if you disconnect the rear servo? Are you running 4WS in the comp rigs that this setup works in? or a single servo? The problem reads like a problem when both F/R steering servos are connected at the same time. Rear wired normally to the RX and Front running single RX wire only. Possibly a ground loop or interference issue. |
This one is nuts - Similar Threads | ||||
Barrel nuts !!!!!!!!!!!!!I'm going nuts | mydoddy69 | Losi Micro-Rock Crawler | 10 | 09-12-2011 05:32 PM |
Check out these nuts | vacrawler | Losi Micro-Rock Crawler | 3 | 01-26-2010 04:48 PM |
Are they F'ing nuts? | Duuuuuuuude | Chit Chat | 36 | 01-23-2010 06:47 PM |
Not sure if its been done.. Im a little nuts!! | S-Dog | Tamiya TLT Crawlers | 19 | 06-26-2007 05:56 AM |
