02-08-2013, 10:26 PM | #1 |
RCC Addict Join Date: Apr 2012 Location: Land of 10,000 Lakes
| FlySky rec. and Axial trans.
I have the Axial AX-2 transmitter, and a flysky receiver, and was wondering... how do I bind them? I heard that the axial radio systems are just rebranded fly skys so this should work right? Thanks, Mitchell |
02-09-2013, 09:23 AM | #2 |
| Re: FlySky rec. and Axial trans.
no one? I need some kind of answer asap. I just found out my cousins are coming over, and I would like to be able to have 2 cars running at the same time.
02-09-2013, 09:49 AM | #3 |
Quarry Creeper Join Date: Feb 2011 Location: Las Vegas 89121
| Re: FlySky rec. and Axial trans. I tried to bind a Flysky TX to a axial RX with no luck, don't know if it will work other way around. I think you'll just have to give it a try.
02-09-2013, 10:05 AM | #4 |
I'm pretty sure the 2 aren't compatible.
02-09-2013, 10:12 AM | #5 |
Pebble Pounder Join Date: Feb 2011 Location: Burnaby, BC
I bound an axial AX-3 to a flysky receiver with 0 issues. I had read previously that an ax-2 may run a little different and is incompatible. Here's a video on how to bind an AX-3, I imagine the ax-2 should be pretty much the same. Give it a shot and let us know. Axial - Binding the AX-3 Radio and Receiver - YouTube |
02-09-2013, 10:22 AM | #6 |
Thanks bro I'll go and try that right now.
02-09-2013, 10:31 AM | #7 |
didn't work... |
02-09-2013, 12:42 PM | #8 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
Look in your manual.. it will work.. i have done it..
02-09-2013, 12:52 PM | #9 |
only reason I didn't want to use the stock rec. is that it's huge! but I threw it in anyways. Didn't need the extra channel. Thanks For all of you help! |
FlySky rec. and Axial trans. - Similar Threads | ||||
axial receiver work with flysky radio? | m1009cucv | Electronics | 7 | 07-26-2012 07:00 PM |
Axial/Edge/VF Dig w/ 3 Channel Rec. | SLOB | Electronics | 6 | 03-27-2008 09:36 PM |
