02-10-2013, 08:00 PM | #1 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Motor Issue
So I got my first motor wound up and plugged it into a battery to test it... at first it wasn't working at all but I barely turned the shaft and it started spinning... But after about 10 seconds it starts to kinda lose power instead of keeping consistent power... I tried it with a couple fully charged 2s batteries... What would be the issue?
02-10-2013, 08:12 PM | #2 |
Rock Crawler Join Date: Oct 2010 Location: NW Washington
| Re: Motor Issue
What motor?
02-10-2013, 08:14 PM | #3 |
| Re: Motor Issue |
02-10-2013, 08:33 PM | #4 |
| Re: Motor Issue Good luck with the building.
02-11-2013, 01:41 PM | #5 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
| Re: Motor Issue
Uh, who wound it? Later EddieO |
02-11-2013, 01:45 PM | #6 |
| Re: Motor Issue |
02-11-2013, 02:57 PM | #7 |
| Re: Motor Issue
I know how the originals were built, I meant who wound this one? From his post, it sounded like he many of done it. Later EddieO |
02-11-2013, 08:24 PM | #8 |
| Re: Motor Issue
Ahh...gotcha. I didn't catch that the first time I read his post... |
02-13-2013, 10:27 AM | #9 |
| Re: Motor Issue |
02-13-2013, 11:11 AM | #10 |
| Re: Motor Issue
Now don't take this the wrong way, as last time I advised someone on this I got labeled the asshole on the forum. First, even if you managed to wind it correctly, how were you gonna terminate it, epoxy it, and balance it.....these are all special processes that take expensive equipment and materials to do correctly, especially if the item is going to be sold to the public. Winding with the small arms is a pain. It's not as easy as everyone makes it out to be......the small wire has VERY thin insulation, so it is easy to scratch off. When to areas connect, the arm gets a short. Further more, Epoxy is very important on the smaller arms. Even the slower winds move fast enough to vibrate the wires and make them move....moving causes friction, friction rubs off insulation.....SHORT happens. There is a reason the slot car guys (who arms are similar size) have crazy epoxy setups and they don't do anything that vibrates the arm (like an ultrasonic cleaner). Balance is gonna factor in on the vibrations....balance is needed. Only a few balancers can do the smaller arms. A quillen can't do them, a Heins could if you wanna reconfigure it...A Hoffman is the standard in slots.......... It's cool you got his stock, but I would get them done correctly like Rockhard did........what you have in your hands is the last of those in the world.....all the molds and dies are destroyed. Later EddieO |
Motor Issue - Similar Threads | ||||
Motor Issue | mlaliberte1 | Electronics | 2 | 05-08-2012 05:59 PM |
Motor issue..need help | BAXTER | Electronics | 3 | 01-14-2012 04:45 PM |
HH Motor issue | armycrawler101st | Electronics | 13 | 09-12-2011 10:26 AM |
Motor Issue | adamtrax | HPI Wheely King | 4 | 07-14-2007 06:09 PM |
Motor issue | xjman | Electronics | 11 | 01-15-2007 06:33 PM |
