02-12-2013, 08:47 AM | #1 |
| Tekin Pro4 vs. Roc 412
So I've read, and read and read for about a week looking for info, trying to decide which one to go with. Which is the better of the 2 the Pro4 or the Roc 412? It will be going in my 9.5lb Wraith and used for both crawling and trail bashing. I run everything on 3s. Let's here some opinions on which is best and why.
02-12-2013, 09:03 AM | #2 | |
RCC Addict Join Date: Nov 2005 Location: Utah
| Re: Tekin Pro4 vs. Roc 412
I've done a bit of thinking on the new roc 412 as well. It seems the pro4 has just as much (if not more power everywhere-noted by users, and is cheaper)? If that's the case, go with the pro 4 3300, 60t 32p spur, 12t 5mm novak pinion. I was in the same debate last week and stuck with the pro4. So i purchased pro4 #3. If the price of the motors were the same i might try it. Here's a good tid bit of info. Quote:
02-12-2013, 09:07 AM | #3 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Depends. What ESC do you want to run? Are 5mm pinions a problem for you? They're very similar motors at the end of the day, so if you have to ask I would think it's going to come down to what's more convenient for you. |
02-12-2013, 09:08 AM | #4 |
So John says the Roc 412 for crawling and trailing. I'll have to shop around some. Any more opinions?
02-12-2013, 09:12 AM | #5 |
The cheapest I've found either motor was $134.99. So they are the same price. But I'm still torn between the 2. What make 1 better than the other, other than the kv options?
02-12-2013, 09:13 AM | #6 | |
| Re: Tekin Pro4 vs. Roc 412 Quote:
I'm running a MMP, and no the pinions are no problem to me. | |
02-12-2013, 09:15 AM | #7 |
| Re: Tekin Pro4 vs. Roc 412 The pro4 has done really well at trailing and crawling for me too. Really. You won't be disappointed with either. Personally, for a 9.5lb wraith i'd go with the pro4. If i was putting the motor in the new vaterra twin hammers rig i'd probably try the roc412 because its a lighter, and smaller rig. Just my .02
02-12-2013, 04:59 PM | #8 | |
Rock Crawler Join Date: Mar 2011 Location: sebastopol
Sorry for the novel,but wanted to share my opinion and experience with the PRO4. | |
02-12-2013, 05:07 PM | #9 |
I already have 32p gears so that's no problem. I wish I had the coin for a 2 speed. I do technical crawling as well, but trailing and loose dirt gravel and rocky hill climbs are fun sometimes as well.
02-12-2013, 05:49 PM | #10 |
Rock Crawler Join Date: Oct 2011 Location: Vertical Junkie
Neither... Tekin 4.5 SC4X 550.... Pro4 doesnt even come close.....3s for 18 mos now on hard rocky terrain. Plus, better bottom end than either the Roc or Pro4... Besides, you are going to want the 5mm shaft after I watched a guy peel the glue off the shaft and stator on his new ROC motor w 3MM shaft... 2 speed No way either. Cushdog just shattered his RC4wd Tranny front outdrive on his Wraith the other day, we heard it snap.... Ouchy... |
02-13-2013, 01:29 AM | #11 | |
02-13-2013, 03:08 AM | #12 |
Pebble Pounder Join Date: Aug 2012 Location: Finland
What are the power specs of the pro4 and roc412?Power in watts.Why is this info so hard to find?This should be on every frickin' motors specs!Unbelievable!
02-13-2013, 03:47 AM | #13 |
TNT1, check this thread and you will be answered...
02-13-2013, 08:12 AM | #14 | |
Yeah, it's hard to find info from motors regardless of the manufacturer. | |
02-13-2013, 08:21 AM | #15 |
I read through the whole thing again also. Still isn't much to be found about a side to side comparison of the 2 motors. I want to be sure I'm getting the best motor for my application. Especially since I'll be forking out around $150 after it's all said and done.
02-13-2013, 08:22 AM | #16 |
Quarry Creeper Join Date: Mar 2011 Location: columbus
I been running 17.5 Tekin redine with Tekin RS in my stock gearing SCX10. I am absolutely pleased. Butter smooth crawling and has wheel speed for climbing. I recently waterproof it with liquid tape, so far it has been working great.
02-13-2013, 08:27 AM | #17 |
I have the Redline and I'm looking for just a bit more. That's why I'm asking about the Pro4 vs. the Roc 412.
02-13-2013, 08:33 AM | #18 |
The Pro4 will have slightly better low end control, the Roc412 has slightly higher punch and drag brake. If the KV isn't available in one build, the other type is a natural choice. Power wise- you won't be able to tell a difference between the two. Either is a large step up in power from the Redline, and both do very well in a crawler or off road truck.
02-13-2013, 08:41 AM | #19 |
Ok. That answers it. Last question. Is there going to be a noticeable difference between a Roc 412 3100kv and a Pro4 3300kv? I also worry about it getting to warm. Which one is easiest to keep cool?
02-13-2013, 09:21 AM | #20 |
Quarry Creeper Join Date: Dec 2007 Location: los molinos c.a.
im running the roc 412 3100kv in a 9lb ar60'd truggy with a 32p 60t spur and 10t pinion and its a power house its nice and smooth like a pro4.i do recommend a hd motorplate.heat is not a problem with this motor im running a mmp pro with mine
Tekin Pro4 vs. Roc 412 - Similar Threads | ||||
World release, Tekin ROC 412 | jetboat | Electronics | 431 | 03-19-2014 03:25 PM |
TEKIN Christmas Giveaway! - ROC 412 Crawler Motors | Ty@Tekin | Electronics | 598 | 10-21-2013 07:30 AM |
Christmas Sweetness - Tekin Roc 412 | GrimJeeper91 | Team Losi Comp Crawler | 6 | 01-01-2013 05:47 PM |
Tekin ROC 412 motors in stock! | RPP Hobby | RPP Hobby | 0 | 12-24-2012 10:48 PM |
Tekin ROC 412????? | Soulo747 | Electronics | 1 | 12-09-2012 05:18 PM |
