Thread: general Electronics Help
Old 02-12-2013, 11:36 AM   #1
Default general Electronics Help
Vehicle: HPI Apache C1 Flux – Stock electronics.
Vehicle stopped working. Fresh batteries - no lights on ESC, no power to receiver or servo…nothing. I tested each component separately and verified all working ok. So I decided to put a receiver battery in the “bat” port on the receiver and everything came to life and was working properly. WTF…what would cause this to happen? Why am I not getting any power from the main batteries/ESC to the receiver? The only thing I could think of was that maybe the BEC circuit in the receiver is bad?
Any insight would be appreciated, Thanks!
hasbeen is offline   Reply With Quote
Old 02-12-2013, 03:09 PM   #2
Default Re: general Electronics Help
Can you post pics of your setup? Having a visual will help us help you
Phins Fan is offline   Reply With Quote
Old 02-12-2013, 04:27 PM   #3
Probably the BEC circuit in the ESC at fault.
Does the fan come one when you turn the switch on with a battery connected? From memory the fan should do a quick test when you turn the vehicle on.
SuperRoo is offline   Reply With Quote
Old 02-12-2013, 06:10 PM   #4
Fan does not come on.
Old 02-12-2013, 07:22 PM   #5
+1.....
I say the ESC BEC circuit died (for whatever reason).
You can run an external BEC (most will suggest a Castle Creations 10A BEC) to bypass a problem issue.
Charlie-III is offline   Reply With Quote
general Electronics Help - Similar Threads
lowering the body and the electronics getting the electronics in a waterproof box m1009cucv Axial SCX-10 15 10-01-2011 07:45 PM
The General CoreyHall 2.2 Scale Rigs 35 08-28-2011 10:51 PM
general electronics question honcho1.9 Electronics 7 02-01-2011 06:47 AM
The mini General CoreyHall 2.2 Scale Rigs 14 01-22-2011 02:00 PM
What is it with vendors and RC in general? knuckleslammer Newbie General 59 05-06-2009 08:44 AM
