02-14-2013, 05:58 AM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| question on chargers
is there a difference if the balance port is internal or external? to think of it.. if a cell goes bad and your charging. would it shut down? if that possible.. still have a lot to learn about this.. thanks |
02-14-2013, 06:09 AM | #2 |
| Re: question on chargers
I've had a couple of issues when the charger detected an issue with a cell or lost connection in the balance port and it instantly stops charging and brings up an error screen and tells me the issue.
02-14-2013, 07:11 AM | #3 | |
| Re: question on chargers Quote:
If the pack has an internal balance board, not sure how the charger would know to shut down if you had a bad cell, unless you told it one qty of cells and it saw a different voltage that was unexpected. | |
02-14-2013, 07:17 AM | #4 |
With mine you have to tell it 2 or 3s etc in order for it to even start charging.
02-14-2013, 08:08 AM | #5 |
same with mine need to tell its 2s or 3s.. been a good charger for 36 bucks i was just wondering. still learning as i go
question on chargers - Similar Threads | ||||
chargers? | bigjeff1313 | Electronics | 20 | 11-15-2009 12:24 AM |
chargers | MaxxRunner | Electronics | 0 | 08-30-2008 07:06 PM |
Question about inexpensive Li-po chargers | Larry62 | Electronics | 10 | 05-17-2008 12:09 AM |
??? on chargers | traylor4x4 | Electronics | 7 | 12-14-2006 07:33 AM |
About chargers | jardiniboy | Electronics | 0 | 07-28-2005 03:59 AM |
