02-14-2013, 10:59 AM | #1 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
| BEC - Yes,..I know I need one,....but...
Yes. I've read the Yes you need a BEC thread, but I am looking for info on which might be the best overall, or most popular, or most common that is used. I have a Novak Ballistic Goat3 21.5 combo that came with a BEC, I think it is 5A. (R1) I also have a Novak Timbuk2 13.5 combo that came with one, I think this is 3A, could be 5A. (Wraith) I have MMP SCT ESC with a 1410/3800 combo with a CC BEC which is 10A in my SC10. I now have a THammer and am planning to upgrade to a run fast with the occasional crawl and have a MMP SCT 1415/2700 but it did not come with a BEC. I plan on adding lights as well. My questions; Is the Castle the best for this setup? Would the CC BEC be the best overall simply because of the A rating? What other options for BEC are there? Would a CAP be better? Where? (never used one of these but have seen them as an option.) Thanks ORA |
02-14-2013, 11:13 AM | #2 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
| Re: BEC - Yes,..I know I need one,....but...
Go with the CC BEC
02-14-2013, 11:19 AM | #3 |
Thanks. I was heading that way just because,....but wondered if there might be reason not to or other options. |
02-14-2013, 11:28 AM | #4 |
There is a reason everyone runs a castle bec. It works.
02-14-2013, 11:28 AM | #5 |
Castle Creations 10A BEC is fine for almost all of us. Some peeps with dual steering servos "may" need either 2 BEC's or a single Castle BEC Pro. Since you have/will have 2 Castle ESC's get the Castle BEC & the Castle link. Then you can program faster in the ESC's as well as change the BEC output voltage. |
02-14-2013, 01:07 PM | #6 |
I have a different opinion! The one reason for using CC BEC is if you want to have a higher voltage than 6.0V. If you think 6V is enough then there are plenty of other (cheaper) BECs to pick from! A strong steering servo will pull less than 5A peak, and typically <3A while in use. I use a Turnigy 3A (5A peak) BEC for my Hitec HS-7954SH, and have no problems. I use the ESC's internal BEC for the Rx and lights though. |
02-14-2013, 06:05 PM | #7 | |
| Re: BEC - Yes,..I know I need one,....but... Quote:
BEC - Yes,..I know I need one,....but... - Similar Threads | ||||
BRXL+Castle Link+Bec=? How do i set BEC? | crazyorigin | Electronics | 17 | 11-21-2011 03:11 PM |
Built in bec vs. Rooster Crawler bec for glitching | mudking82 | Axial AX-10 Scorpion | 7 | 12-07-2010 08:57 AM |
using external BEC & esc's internal BEC.... | slowlearner | Newbie General | 2 | 02-14-2010 01:35 AM |
Castle BEC & Castle Link - not finding BEC | Locked Up | Electronics | 22 | 12-20-2007 03:37 PM |
Receiver BEC (vs ESC BEC) | sim | Electronics | 7 | 10-13-2005 07:54 PM |
