02-15-2013, 04:17 PM | #1 |
Rock Crawler Join Date: Feb 2010 Location: rochester, mn
| Castle settings help
Hey guys, I'm building a wraith with a hh Brxl, hitech 7950 and hh pro 35t. I just installed all the hardware on my computer and wondering what i should have everything set at? I'm running 2s lipos., I set the low cut off off for 4.5 volts is this ok? I set the main voltage at 6.5. Should that be at 7.4? Or not? Basically I'm new to all this and I left all the other brake and throttle settings alone because I didn't want to wreck anything.. Any help would be great, thank youm |
02-15-2013, 05:07 PM | #2 |
| Re: Castle settings help
Your cut-off is a little high, but it won't hurt anything. When I set mine I typically go for around 3.4-3.6v. For main voltage I select auto-detect, that way I don't have to fuss with anything if I swap in a battery with higher or lower voltage than I normally run. Brake and throttle profiles are great if you want to get nerdy about stuff...in all my years I've never messed with them. To me its just another thing I have to think about and not really necessary in most cases. |
02-15-2013, 05:41 PM | #3 | |
| Re: Castle settings help Quote:
02-15-2013, 07:57 PM | #4 | ||
You can play with 'em if you want, shouldn't hurt much, and you can go back to a linear setup if you don't like it. But I've gone back to straight linear in all the Castle ESCs I have. | ||
Castle settings help - Similar Threads | ||||
Tekin 3300 4pro and Mamba Max Pro castle link settings | waterboij23 | Axial Wraith | 1 | 07-09-2012 10:24 PM |
Axial AE-2 and Castle link settings | RootBreaker | Electronics | 5 | 07-04-2012 07:11 PM |
Castle MMP (MOA) ESC Settings. | Jcdelcarmen | Team Losi Comp Crawler | 4 | 12-08-2011 12:25 PM |
Castle Link - MM Settings | dkingston | Electronics | 2 | 01-28-2008 08:45 AM |
