02-17-2013, 02:21 PM | #1 |
Newbie Join Date: Feb 2013 Location: Bourne
| Losi night crawler trying to pick the rite motor combo
this is my first crawler rtr the esc crapped out so i was thinking of getting a tekin 17.5 brushless combo if anyone knows if this is a good idea please tell me or a bad idea i have no idea what to do thanks
02-17-2013, 07:17 PM | #2 |
| Re: Losi night crawler trying to pick the rite motor combo
Check the LNC section. |
02-17-2013, 07:27 PM | #3 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
Most of the hardcore guys run the 13.5.
02-17-2013, 07:52 PM | #4 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
If you are still running the stock Nightcrawler "trans" if you wanna call it that, a good 35T brushed motor will be a good choice. The stock Losi motor is actually a 35 labled as a 55. If you are running the Comp Crawler trans with the dig, you will definitely want a brushless setup since they are hard on brushed motors. Just about any ESC will work in that thing since the axles act as a natural drag brake.
02-18-2013, 10:24 AM | #5 |
the worm gears eat brushed motors, go brushless
02-18-2013, 10:28 AM | #6 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
| Re: Losi night crawler trying to pick the rite motor combo |
02-18-2013, 01:16 PM | #7 | |
| Re: Losi night crawler trying to pick the rite motor combo Quote:
02-18-2013, 01:29 PM | #8 |
A brushed motor with that trans will be ok. I ran mine with one until I installed the Dig trans from the Comp .
02-18-2013, 01:33 PM | #9 |
Rock Stacker Join Date: Aug 2012 Location: Schenectady
If you are just going to run brushed, Holmes Hobbies is hard to beat. I run a 16T Crawlmaster with their BRXL and 3s and it has gobs of power.
02-19-2013, 01:49 AM | #10 |
| Re: Losi night crawler trying to pick the rite motor combo As said before. A brushed motor in a Losi would be a poor choice and will wear out fast. The drivetrain needs the torque of a brushless since there is so much power lost due to the worm gears. So no brushed motor will last to long. Your best bet is 13.5t or 17.5t brushless system.
02-19-2013, 04:47 AM | #11 |
RCC Addict Join Date: Dec 2011 Location: Australia Queensland!
13.5T or 17.5T tekin redline with Castle Mamba Max. Best setup have a search and read up.
02-19-2013, 07:40 AM | #12 |
Rock Crawler Join Date: Nov 2009 Location: poteau
while a brushed motor will hold up in the LNC, i would still go brushless. one of the biggest downfalls to brushless is the drag brake. well in the losi with worm gears you don't need drag brake! i would skip the 17.5 and go straight to a 13.5t tho. after a while of running mine i found that the 17.5 had gobs of torque but just didn't have the instant wheelspeed to bump up and over alot of obstacles. the 13.5t still retained the torque needed AND added that burst of wheelspeed needed for steep climbs, slippery rocks and bump overs. just remember whichever motor you choose, make SURE its a sensored system!!! |
02-20-2013, 04:55 PM | #13 |
thank u guys u all have helped me make my mind up i will be getting the 13.5 tekin brushless combo if anyone whants to me no get this tell me why should not go to order it in four days
Losi night crawler trying to pick the rite motor combo - Similar Threads | ||||
Losi night crawler motor esc? | Chillaxeing | Team Losi Comp Crawler | 2 | 08-26-2012 11:45 AM |
losi night crawler esc motor limit? | mini freak | Electronics | 1 | 09-24-2011 07:32 PM |
Help me pick motor/ESC combo please | crfnick56 | Electronics | 10 | 10-27-2010 02:24 PM |
Losi night crawler Motor | jake27 | Team Losi Comp Crawler | 4 | 01-19-2010 08:56 PM |
motor/esc combo for new losi crawler | snowsurfer715 | Electronics | 2 | 03-19-2009 09:31 PM |
