02-22-2013, 05:57 PM | #1 |
Quarry Creeper Join Date: Aug 2009 Location: Snohomish, WA
| FXR with 3100kv ROC412?
I'm having difficulty convincing myself to buy the Tekin RS esc @ 200+ bucks! My question is will the tekin FXR esc on 3s handle the 3100kv roc412? Which ESC do you recommend to go with? Thanks, Mike Sent from my iPad using Tapatalk HD |
02-22-2013, 06:01 PM | #2 |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
| Re: FXR with 3100kv ROC412?
The fxr will NOT work with the roc 412 motor. The fxr is a brushed only speed control and the roc 412 is a brushless motor. If you are sticking with tekin your only choices are the rs, rs pro or an rx8 (1/8th scale).
02-22-2013, 06:03 PM | #3 |
Thank you, I didn't realize that.... Sent from my iPad using Tapatalk HD |
02-22-2013, 06:25 PM | #4 |
Rock Crawler Join Date: Nov 2010 Location: Springfield, Oregon
As mentioned above, an FXR will absolutely not work with a ROC412. An option I would look at is a Mamba Max Pro. Easy to find used for $80-100, or new for $100.
FXR with 3100kv ROC412? - Similar Threads | ||||
Tekin ROC412 knocking noise | cytogen | Electronics | 45 | 04-11-2013 02:08 PM |
TEKIN ROC 3100KV help | Pegasix | Electronics | 12 | 02-22-2013 11:52 AM |
Gmade and Tekin, roc412 | cytogen | G-Made Crawlers | 0 | 01-25-2013 02:42 AM |
