02-23-2013, 02:44 PM | #1 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
| CC BEC No Worky
So I got CC BEC and connected it to a MMP SCT with a CC 1415-2700kv. Set the ESC up and everything worked great for about 1/2 a battery, then it died. I thought it was the receiver so swapped them out and it still was jittery when I connected the battery. Then decided to remove the BEC from the connection and start everything up. Perfect! Everything runs and runs great just like I expected. Hook the BEC back up and power ON and the steering is jittery and the motor doesn't run. Unhooked - Great!! Do I have a bad BEC? ORA |
02-23-2013, 02:53 PM | #2 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
| Re: CC BEC No Worky
I'm by no means an expert on this, but I would check the connections to see if they're good. I don't really know, but see if there is any programing needed to be done. Good luck and hope you get it working!
02-23-2013, 03:10 PM | #3 |
Rock Crawler Join Date: Apr 2010 Location: Kelowna, B.C., Canada
| Re: CC BEC No Worky
I would assume you have the red wire from the esc disconnected when you have the bec plugged in? Do you keep the esc ground wire while the bec is plugged in? Sometimes that has been the culprit for me. It could also just be a bad bec, first I would try to load an older version of firmware to the bec if possibly. |
02-23-2013, 03:37 PM | #4 |
| Re: CC BEC No Worky
Yes. RED wire is disconnected from ESC lead. RED wire from BEC is soldered to the RED wire of the ESC battery connection. BLACK wire from BEC is soldered to the BLACK wire of the ESC battery cnnection. (or at least they were. I can recheck that to verify) Haven't messed with the firmware/programming of the BEC. Just hooked it up and ran it. |
02-23-2013, 04:36 PM | #5 |
Green light on the Bec.. is it on? Is it bright? I had one similar, green power light was on but was dim.. had stuff goin back to castle so it went with it, they replaced it |
02-23-2013, 06:59 PM | #6 |
| Re: CC BEC No Worky
Bright green. Just unhooked everything and found the Shift servo is bad (twinhammer). Left the shift servo unhooked and connected everything else. Green light on the BEC. No glitching. No sputtering. No crap behavior. Worked perfectly (for the 3 minutes I had it on). Not sure if the shift servo failure had anything to do with the BEC, but it seems to have resolved the issue, so far. |
02-23-2013, 08:54 PM | #7 |
RCC Addict Join Date: Apr 2012 Location: Williamsport, PA
| Re: CC BEC No Worky
Yes bad servos can mess with the rest of the system.
CC BEC No Worky - Similar Threads | ||||
worky? | demonoid369 | Testing 1 2 3 | 0 | 12-04-2011 10:00 PM |
mamba monster no worky worky help please | 1buktooth | Electronics | 6 | 08-15-2009 04:34 PM |
servo stretcher no worky! | NCcrawler | Electronics | 5 | 03-30-2009 01:10 AM |
My avatar no worky? | 4xFord | Testing 1 2 3 | 2 | 09-10-2008 12:21 PM |
for sale forum no worky | supercrawlerfreak | Chit Chat | 26 | 05-10-2006 09:13 PM |
