02-24-2013, 09:13 PM | #1 |
RCC Addict Join Date: Feb 2010 Location: New Jersey shore
| cutting brushless motor wires shorter.
can this be done with no problems? thanks
02-24-2013, 09:39 PM | #2 |
| Re: cutting brushless motor wires shorter.
Yes.
02-24-2013, 10:22 PM | #3 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
If you are talking about motors that have the wires coming directly out of the motor, no, don't cut them. Those wires are direct from the stator and cutting that wire will alter the stator. Also, it is very hard to solder the wire that comes out the BL motors doe to the wire itself.
02-24-2013, 10:47 PM | #4 |
Rock Crawler Join Date: Dec 2011 Location: Las Vegas 89110
x1 some you can some you cant. tell us what motor and im sure someone will chime in to let you know
02-25-2013, 06:44 PM | #5 |
Newbie Join Date: Jul 2010 Location: LRAFB, AR
Im assuming its a sensorless motor. Yes you can, but you have to ensure they are all equal length when you cut them
02-25-2013, 07:07 PM | #6 |
Some motors you can and others you can't. You'll need to look at what the manufacturer says for the particular motor.
02-25-2013, 07:27 PM | #7 |
If the wires are flexible and noodly, yes, you can cut them. If they are stiff and stay bent when you flex them, then no, you can't cut them.
02-25-2013, 07:34 PM | #8 |
its a tacon 96m11 2848-4300kv. yes they come right out of the motor
02-25-2013, 07:37 PM | #9 |
You can't cut wires on a Tacon.
02-25-2013, 08:00 PM | #10 |
got it thanks
08-28-2013, 05:01 PM | #11 |
Rock Crawler Join Date: Oct 2011 Location: Great Outdoors
| Re: cutting brushless motor wires shorter. So I'll just kick up an old thread instead of starting a new one. Why on earth can't you cut/splice any wire? If it's a non-solderable wire that's crimped in the connector -- okay I'll buy that. But I don't get the people who say you'll change the wire's length. That wire goes all the way to the esc and it's whatever length I choose. Electrons don't know where the connector is. (Do they? ) |
08-28-2013, 05:41 PM | #12 | |
| Re: cutting brushless motor wires shorter. Quote:
The non-noodley wires are the same wire that was used to wind the motor and it coated with a resin that you have to be extra careful to strip off cleanly and solder properly. You technically can cut and resolder, but its something you shouldn't do unless you are at least pretty fair with a soldering iron. A crappy solder there will do damage to the esc or motor. Otherwise, the wires still need to be the same length as a different length will result in a different resistance. In all actuality it may not be enough to make a difference (unless one is way short) but its a good practice to keep. | |
08-29-2013, 02:08 AM | #13 | |
Given the internal resistance per meter in the wire compared to the differences in resistance between the individual motor-ESC connectors I'd rate "same length" to be "give or take an inch". To really have the same resistance one must measure resistances A-B, B-C and A-C at the ESC, using an ohmmeter with a precision of 0.1 milliohms or better. | |
08-29-2013, 11:13 AM | #14 |
I'm not exactly sure what the tolerance is, but as I said its just a good practice to keep them as even as possible. I'm a big fan of balance and symmetry. |
08-29-2013, 12:22 PM | #15 |
Rock Crawler Join Date: May 2008 Location: At the corner of Bedlam and Squalor.
Been there, done that. They are simply extensions of your stator windings. if they get uneven, your esc may throw a hissy fit. Keep them even. It'll probably be fine.
09-13-2016, 10:19 AM | #16 |
Newbie Join Date: Sep 2016 Location: Omaha
I have a 18-11 2000kv Micro Brushless Outrunner (10g) and accidentally pulled one of the 2mm banana plugs off. Now that I have soldered it back on, that lead is 3.5mm shorter than the other two. Is this going to be an issue with performance or a danger to my motor or ESC? I would sure like to know before I put power to it.
09-13-2016, 10:41 AM | #17 | ||
Did the wire break off? Maybe they just didn't solder the other bullets in the same spot. But it really isn't too big of a deal. Resistive differences to motor phases are not critical when they are outside of the stator. Good to be balanced, yes. But don't worry about a little difference on a little motor. | ||
09-13-2016, 10:41 AM | #18 |
RCC Addict Join Date: Jan 2016 Location: Kelowna, BC
3.5mm shouldn't cause an issue.
09-13-2016, 10:50 AM | #19 |
Rock Crawler Join Date: Feb 2012 Location: OC
NIKE! Just do it, and learn...... That's the way of the West.... |
09-13-2016, 10:54 AM | #20 |
Quarry Creeper Join Date: Oct 2014 Location: East
Your looking at a difference measured in the micro ohm level. The current change between what it was, and what it is now is negligible. What you really should be concerned with is making sure that the enamel on the motor wires is fully cleaned, making sure ALL wires carry current. Sent from my XT1575 |
cutting brushless motor wires shorter. - Similar Threads | ||||
Shortening wires on brushless motor/ESC | khwilliams | Electronics | 6 | 03-24-2012 08:49 PM |
Need a shorter motor!!! | The Jackalope | Electronics | 0 | 02-14-2012 01:44 AM |
Cutting the power wires on a Novak Rooster | Phylodog | Electronics | 2 | 12-24-2009 09:03 PM |
Shorter motor wires?? | oberon crawler | Electronics | 4 | 08-19-2008 05:09 AM |
making the wires shorter | iceman320 | Electronics | 8 | 06-23-2008 12:13 PM |
