02-25-2013, 05:24 PM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: canada edmonton alberta
| cc 10amp bec to summit servos
Need a diagram ,to hookup 1 cc 10a bec to summit twin steer servos.Have a idea but ,dont want to chance the smoke.
02-26-2013, 08:53 AM | #2 |
| Re: cc 10amp bec to summit servos
If you're at all adept at building your own wiring, you could get some (EMS? I think) unassembled servo connectors and build your own bypass adapter. Brown on BEC to black on both servos and to at least one steering slot in your receiver (blacks and reds in your receiver are usually on a common bus, no real need to run black/brown to both receiver posts, just one. Doing both won't hurt anything, though) red on BEC to red on both servos (servos to BEC only- NOT to the receiver) yellow/tan on BEC gets hooked up to nothing white signals on servos go straight to receiver, nothing else So basically you'll end up with 5 plugs, 1 female w/ 3 blacks and 2 reds for your BEC 2 female w/ 1 balck, 1 red, 1 white for your servos 1 male w/ 1 black, 1 white for a channel 1 slot on your receiver 1 male w/ 1 white for the other channel 1 slot on your receiver With this setup, no pulling of any wires on your ESC's connection, as the BEC will feed the servos, and the ESC will power the receiver. .................................................. ................ Or..... Leave your stock servos plugged in, pull the red wire where your ESC connects to the receiver, plug the BEC into any open slot. This way the BEC will feed the receiver, and the receiver will feed the servos. |
cc 10amp bec to summit servos - Similar Threads | ||||
Castle 10amp BEC FIRE | johnnyh66 | Electronics | 15 | 05-07-2012 06:38 PM |
