02-27-2013, 07:40 AM | #1 |
Quarry Creeper Join Date: Dec 2011 Location: poplar blufff,mo
| Mmp calibration issues
Just got a Mmp from castle hook up all wires ran it frist with a Novak 13.5 seemed fine decided to back to brushed put on a 19t intergy and now I'm stuck on the faster reverse than forward problem. I have tired recalibrating switch to my fly sky radio tired it with a dx3e chamged settings in the castle link software. I'm lost. My setup Mmp wired to Novak bec running a 3s and 2s max c ratings are 30. Hacked flysky. What am I missing? I did try to reverse motor setting in the castle software still no go Help Sent from my Galaxy Nexus using Tapatalk 2 Last edited by idk; 02-27-2013 at 09:12 AM. |
02-27-2013, 07:50 AM | #2 |
| Re: Mmp calibration issues
Did you set the reverse power to 100% and the forward power to less on the ECS or something?
02-27-2013, 07:58 AM | #3 |
That 19t probably has a shit ton of timing, in the wrong direction.
02-27-2013, 09:11 AM | #4 |
no my reverse power is set to 50% default i belive i did update to the newest firmware 1.38 i think. so is the 19t a no go with this esc? it ran super duper with my fxr?
02-27-2013, 09:33 AM | #5 |
ok i see the motor has 24*of advanced timing and its adjustable. so should i set this to 0*?
02-27-2013, 12:42 PM | #6 |
About six degrees in the other direction should be good, so go to zero, then six more.
03-02-2013, 08:37 AM | #7 |
ok this is driving me nutz!! i moved the timin around there was no number or anything for me to see what zero was so i just moved it around till it was right. soi got forward and rev power right more forward that back. but....... i have no torque now on any motor i try brushed or sensored. it will move along on flat just fine try to crawl up a wall and it wont budge tried to go up a little maybe 2 foot hill i go up all the time and it barely makes it. i charged all my lipo 2s 3s volts are all good i get a green in forward an dred in rev. reset all setting to default in castle link. nothing works. i have yet to get this esc to preform!! motors are good sensored went back in my slash good to there. the brushed worked great in my 1.9. idk what to do!! castle says send it back. but i just got it and really wanna make sure im not doin something wrong. is there anything else i need to look at? i took the brushed apart and no carbon buildup looks good to me. im lost help please
03-02-2013, 02:55 PM | #8 |
| Re: MMP calibration issues
When you're switching between brushed & brushless, you're changing the setting in the ESC to match, correct? Are you calibrating the ESC to the RX? What ESC firmware are you running? AFAIK, 1.28 is the best crawler firmware to use. The latest version seems to have issues for us. I'm on the road and don't have my rig with me to double check. Is this a Mamba Micro Pro or a Mamba Max Pro? |
03-02-2013, 03:31 PM | #9 |
Max pro and yes I switched everything in castle link. I bought a cheap venom 35turn today and bam power. Then the motor smoked in ten minutes but I don't think that was the esc fault I was running it through some muck and it must have got splashed. But it worked right for a sec. Then I got to looking at the sensor motor I have 17.5 track star and the timing is set to zero on it. Should change this I never touched the timing on this motor thought I did but didn't. I really want to use this Damn 19turn and not the brushless setup it's going to the slash Sent from my Galaxy Nexus using Tapatalk 2 |
03-03-2013, 08:16 PM | #10 |
SOLVED 19t was toast not sure why but it will not work anywhere now set the timing to 6 in castle link on the 17.5 switched to 1.28 firmware and im runnin again. thanks alot for the help guys.!!!!!!!
Mmp calibration issues - Similar Threads | ||||
FXR Calibration | KnoJa | Electronics | 9 | 12-26-2012 09:06 AM |
CC SW and 3pm-x calibration issues | stewbaru | Electronics | 3 | 08-30-2010 11:29 PM |
MMP fan issues. | djjiz | Electronics | 7 | 08-09-2010 01:04 PM |
issues......MMP and excelorin 17.5 | KrawlerKing | Team Losi Comp Crawler | 22 | 07-13-2010 08:47 PM |
Spektrum 2.0 and Mamba Calibration | RocSpyder | Electronics | 1 | 01-17-2009 08:57 PM |
