03-01-2013, 12:03 AM | #1 |
Pebble Pounder Join Date: Feb 2011 Location: lost
| HELP!!! fxr over heating problems
so i hooked up everything and turn on my fxr to change the voltage cutoff to run my 3s lipos and i was using a ni-mh pack and i go to change it and it was really hot... im running 2 servos a 3 racing winch and the motor... do i need a bec? led 1 3 and 5 are flashing and the fxr manual says Voltage Cutoffset below battery voltage or in hi-temperature thermal shutdown so could it be that i was trying to use to much power? the 2 servos are connected by a y connector and the actueal steering one is a savox 1/8 scale servo and i have one for a steering wheel mod and its metal geard and i have a 3racing winch hooked up to the reciever is there anything i can do to fix this problem tonight? |
03-01-2013, 04:58 AM | #2 |
| Re: HELP!!! FX-R over heating problems
General rule of thumb, when you get over ~200inoz of servo torque, you NEED an external BEC. If your 2 servos are ~100inoz each, you're about there, if they are higher torque, you are definitely there. Then add in your winch. To set-up the FX-R, unplug the servos and do your changes. |
HELP!!! fxr over heating problems - Similar Threads | ||||
Fxr problems | ax-10 crazy | Electronics | 2 | 02-20-2011 03:50 PM |
FXR Problems maybe? | oneeye | Electronics | 2 | 10-06-2010 09:44 PM |
HELP fxr ccbec problems | dgfordman | Electronics | 28 | 11-30-2009 02:14 AM |
Tekin FXR problems | 671offroader | Electronics | 2 | 11-19-2009 06:36 AM |
FXR Problems. | Terminator13 | Newbie General | 5 | 08-17-2009 11:37 PM |
