03-01-2013, 01:22 PM | #1 |
Quarry Creeper Join Date: Jul 2010 Location: williams county
| led wiring questions
I want to run two led's on the front of my bug. I don't have them yet because I don't know which ones to get. I modified a servo so that I can supply power on and off from the 3rd channel on my receiver. What led's should I get? |
03-01-2013, 01:26 PM | #2 |
Rock Crawler Join Date: Oct 2012 Location: Garden Grove
| Re: led wiring questions |
03-01-2013, 01:31 PM | #3 |
awesome, thanks for the links :]
03-01-2013, 01:48 PM | #4 |
np. I used these links all the time when I was trying LED wiring out. Have fun with it. You can get 50ct/100ct packages of LEDs of eBay for usually under $20 and there are some pre-wired ones if you don't want to mess with the LED soldering, just the wiring portion. |
03-01-2013, 01:53 PM | #5 |
soldering is fine for me :] just wish I didn't have to buy 50 when I only need 2, LOL |
03-01-2013, 02:01 PM | #6 |
how about these LED Ultra Bright White 10mm Big 2 Pcs | eBay |
03-01-2013, 02:06 PM | #7 |
10mm is large. The stock Wraith ones are 5mm, as are most other led kits. I've seen 3mm as well for turn signals and such, but 100mm might be oversized for a model. I'd probably stick with 5mm and see if you can find the ultra ones, otherwise the normal bright white will be bright enough. |
03-01-2013, 02:13 PM | #8 | |
Pebble Pounder Join Date: Dec 2010 Location: Fresno
| Re: led wiring questions Quote:
If you look around ebay you can find smaller counts for less. I got 50 for like 4-5 bucks. | |
03-01-2013, 02:13 PM | #9 |
my scale build will have 9 5mm and possibly 2 3mm but this one is getting some really silly lights. 70's rally style :P The lenses are 24mm in diameter |
03-01-2013, 02:17 PM | #10 |
| Re: led wiring questions Same here. Different colors and sizes. LED throwies. LED candles. LED night lights. LED pet collars. LED ATV accents lights. LED hat brim lights. .... .... .... .... etc. |
03-01-2013, 02:19 PM | #11 |
03-01-2013, 02:38 PM | #12 |
however, 5mm might make more sense financially since I need them for the other body. How about these 30 x LED White Ultra Bright Water Clear 5mm USA Seller Free Shipping | eBay |
03-01-2013, 02:50 PM | #13 |
That looks good. Here's a package with resistors. I know this is 100pc, but 4 colors. The calculators I listed previously will give you the resistor you will need based on your series. You can get those from theShack or eBay too. |
03-01-2013, 03:22 PM | #14 |
nice, I'm going to order the ones you linked with the resistors :]
03-01-2013, 03:29 PM | #15 |
It's always good to have extras. Pins break, LEDs can blow, typical other electrical issues. Start laying out your series too with the input voltage/3.3 (white LED)/20mA. This will tell you which resistors you actually will need based on your series. Then go back to eBay and get MORE STUFF!!!!!! |
03-01-2013, 03:35 PM | #16 |
I have been out of this kinda thing so long, I forgot which side the resistor gets soldered to, lol
03-01-2013, 04:03 PM | #17 |
03-01-2013, 04:05 PM | #18 |
03-01-2013, 04:05 PM | #19 |
03-01-2013, 04:07 PM | #20 |
thanks guys. I will keep you posted |
led wiring questions - Similar Threads | ||||
3rd channel led light wiring | Ur2respect | Electronics | 14 | 01-11-2011 02:34 PM |
led wiring ? | yoda316 | General Scale Talk | 14 | 01-09-2011 08:09 PM |
tr bec wiring diagram with led lights | alaskancrawler | Axial SCX-10 | 1 | 03-24-2010 08:47 AM |
LED wiring info | Nate08 | Electronics | 0 | 06-03-2009 05:39 PM |
LED wiring questions? | JavelinSST390 | Electronics | 3 | 11-11-2007 11:41 PM |
