03-02-2013, 09:33 PM | #1 |
Quarry Creeper Join Date: Apr 2012 Location: lake wylie
| xl5 mod?
Ok I am dumb with what goes on inside an esc but has anyone here ever or has known someone to mod an xl5 esc to have a drag brake? The reason im asking is I just swapped from one xl5 to another that already had a deans plug on it so I could run my lipos. I had bought it used and had not run it in anything until now. Now my ax10 has drag brake! With the new one it will hold dead still on a steep incline where the old one would just roll Other than using the exact same modle esc and swapping to lipo nothing else has been changed. So should I not look a gift horse in the mouth? Or could this be a sign of issues somewhere in my drive train? I didnt run it long enough to see if the battery wore down too fast though. Its also running a 55t motor that worked fine with the other esc. |
03-02-2013, 09:48 PM | #2 | |
RCC Addict Join Date: Oct 2009 Location: In the mancave...
| Re: xl5 mod? Quote:
03-02-2013, 09:54 PM | #3 |
Newbie Join Date: Apr 2012 Location: Somewhere in Vancouver
| Re: xl5 mod?
I work at a hobbyshop and have been dealing with the vxl systems for the last 2 years. In all my dealings I've never had one that didnt have something wrong with it to cause it to act like it has a drag brake. I'd scope out everything in your drivetrain and see if you feel any binding issues anywhere.... I'd be real carefull with binding issues that can wreak havoc on batteries and the ESC. Good Luck and feel free to post up any other questions you have.
03-02-2013, 10:29 PM | #4 |
Newbie Join Date: Dec 2011 Location: Giles
| Re: xl5 mod?
I have an xl5 in my scx10 and it acts the same way as you described
03-03-2013, 12:25 PM | #5 |
| Re: xl5 mod?
Its as I feared I guess. Well time to break out the WD40 grease and bearing oil. Og while I got my ax10 torn down would it be a good idea to throw a titan monster 550 motor in it. I happen to have a good one just laying around.
03-03-2013, 10:11 PM | #6 |
| Re: xl5 mod?
Ok turns out not to be an electronics issue after all. My wheel spacers in the rear where rubbing the lockouts. Added a small washer between the hex and spacer for a shim and all good.
xl5 mod? - Similar Threads | ||||
Xirtic + JP High Clearance Steering Mod on Mod | JeffK11 | RC4WD Bully | 1 | 02-01-2012 09:55 AM |
Front Dig Mod,steering mod & pushbar | TheButcher69 | General Crawlers | 1 | 11-06-2006 06:32 PM |
