Thread: motors
Old 03-02-2013, 11:22 PM   #1
Default motors
I'm a newbie to rc crawling.I'm looking to upgrade my rs10xt's 390 motors to 540 motors.I want motors with decent speed and alot of torque.My question is what does the turns have to do with torque and speed?If I wanted more torque would I go with a higher motor turn or a lesser turn?55 versus 27 turns.
rccrawler39 is offline   Reply With Quote
Old 03-03-2013, 06:54 AM   #2
Default Re: motors
More turns = more torque, less speed.
Less turns - more speed, less torque.
You can make up for a little either way with battery voltage (more voltage = more speed) or gearing.
There are limits on voltage & gearing though.
Charlie-III is offline   Reply With Quote
Old 03-03-2013, 07:36 AM   #3
Default Re: motors
55T will be slower and have more torque than a 27T.
He's asking about an MOA. The only gearing change options available for that truck are different pinions.
JeremyH is offline   Reply With Quote
Old 03-03-2013, 10:28 AM   #4
Default Re: motors
Yes, I know....changing pinions is still changing gearing although options are lessened quite a bit compared to also being able to change spur gears.
But thanks for pointing it out.
Old 03-03-2013, 11:08 PM   #5
Default Re: motors
Thanks for the help guys.truly appreciated.
motors - Similar Threads
Speed/Torque difference between Crawler motors/Normal motors? dynamic_e Electronics 5 10-08-2010 10:26 AM
