03-04-2013, 05:08 PM | #1 |
Quarry Creeper Join Date: Apr 2012 Location: lake wylie
| servo reverser
I decided to build 4ws for my ax10. Im running a constant 4ws since my punk rock crawler computer has 2 leads cut off by a previous owner and I dont have the serial adapter to program it. I know I need a servo reverser for the back axle. So my question is where to buy it from? I know the turnigy one is cheap as heck but even for the price is it any good? I get real sceptical when something is so much cheaper than all the competitors. Im trying to do it the right way the first time. |
03-04-2013, 05:52 PM | #2 |
Quarry Creeper Join Date: Feb 2008 Location: US
| Re: servo reverser
You should be able to do this one of two ways. -The best way is to use your radio. If you have a high end radio, they allow for mixing and you can customize response the way you want it. -I believe you can swap pos/neg wires at the pot. Using a switch as you've said is a much better solution than this. As far as turnigy stuff goes, I've always had good luck with their products. Might be worth a try if it's cheap Last edited by hibbs; 03-04-2013 at 05:57 PM. |
03-04-2013, 09:36 PM | #3 |
| Re: servo reverser
Thanks I did research on reversing servos and I dont quite have the steady hands I use to to reverse it internally and I dont have a radio with mixer capabilities. I just have a couple losi 2ch dsm and a 2.4 3ch system tha originally came with the associated sc10 I use to have. I will give the turnigy unit a try if it fails im just out a few bucks.
03-04-2013, 10:36 PM | #4 |
Quarry Creeper Join Date: Apr 2012 Location: Missouri
| Re: servo reverser
I use a EXR Tamiya Clodbuster 4WS Y-Harness Reverser EXRA325, had it forever but you can still get them. Has a manual trim pot for rear servo. Handy! Like 10 bucks on eBay.
03-05-2013, 06:06 AM | #5 |
| Re: servo reverser
You can get a reversing harness from Holmes Hobbies for cheap.
03-07-2013, 02:31 PM | #6 |
| Re: servo reverser
Thanks guys I will check out the HH unit.
03-07-2013, 07:38 PM | #7 |
| Re: servo reverser
It sounds like you have things taken care of, but maybe check out these 4WS controllers I make. Maybe it will get you going with less hastle: 4 Wheel Steering Controller 4 Wheel Steering Controller - controlled by a two position third channel |
03-08-2013, 11:18 PM | #8 | |
| Re: servo reverser Quote:
03-09-2013, 07:50 AM | #9 |
Rock Crawler Join Date: Nov 2011 Location: clarksville,ar
I have one of these 4ws controllers from Heyok...I love it..the one I have is adjustable to set endpoints in each direction...definitely a good buy if u can get one !!
servo reverser - Similar Threads | ||||
3-Channel Radio or Servo Reverser for 4WS? | kev187 | Electronics | 4 | 07-07-2013 08:45 AM |
Problems with Y Harness Reverser | GuAnAtoS | Electronics | 18 | 01-27-2009 06:54 PM |
Servo Reverser or 3-channel? | kev187 | Tamiya CR-01 | 16 | 01-15-2009 11:44 AM |
Servo Reverser Question | rcr3fan29 | Electronics | 4 | 04-05-2006 11:38 AM |
reverser harness for 4WS?? | TwistedCreations | General Crawlers | 8 | 03-12-2004 12:52 PM |
