03-07-2013, 08:44 PM | #1 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| MMP combo question
Hey guys, most have seen my thread about putting a MMP with a 6900kv brushless system in my Wraith. Some say that is totally stupid and it is overkill, but I think it's just right! Anyway, I have been reading Castle's instructions over and over to see if it says anything about setting up the ESC with the sensorless motor. Is it just as simple as buying the Castle Link and switching it over to Smart Sense/ Sensored mode? I'm getting confused with that part; how does it know the motor's timing?? Thanks! |
03-08-2013, 06:35 AM | #2 |
Rock Stacker Join Date: May 2007 Location: Fort Payne
| Re: MMP combo question
If the sensor wire is plugged in the ESC will see it if not the ESC will run its nonsensored data If you try to go really slow my mmp/6900 experience is twitchy on starts unsensed smooth as butter plugged in. |
03-08-2013, 09:40 AM | #3 |
Pebble Pounder Join Date: Jun 2012 Location: las cruces
It's is that easy plug in the castle lin and then change your settings I run mine in sensor only
03-09-2013, 01:10 PM | #4 |
6900kv is a bit fast. If it's the Castle motor then it's not going to be sensored and not too smooth off the start. If you have a sensored motor I like Smart Sense because it pulls off line smooth then gets up and goes. Then if something happens and I lose sensor cable while out on trail I can still drive it.
03-09-2013, 08:55 PM | #5 | |||
| Re: MMP combo question Quote:
03-09-2013, 09:15 PM | #6 |
Rock Crawler Join Date: Feb 2012 Location: Michigan
The castle motors are not sensored, therefore, there is no plug.
MMP combo question - Similar Threads | ||||
MMP question?? | hatefulboy | Electronics | 9 | 09-16-2012 11:48 PM |
MMP question? | dAng! XJ | Axial Wraith | 3 | 11-17-2011 08:45 AM |
