03-08-2013, 12:03 PM | #1 |
Quarry Creeper Join Date: Jul 2010 Location: williams county
| control lights from channel 3
I know there are a lot of ways to do this... but can I do it this way : connect one of these to channel 3 on my rx Multi-Remote Receiver operated on/off Switch connect a nine volt battery to the switch above, then connect the switch to an array of 7 led's. I know this switch is not normally used for just one thing like that, but the normal switch was back ordered. |
03-08-2013, 12:47 PM | #2 |
| Re: control lights from channel 3
I would think that would work. Or, you could use this which is quite a bit smaller: HeyOK Remote Switch for LED Lighting |
03-08-2013, 12:54 PM | #3 |
thanks Dude. only problem I see with that one is that the lights get their power from the RX. I want to have a separate battery for lighting. |
03-08-2013, 01:56 PM | #4 |
Pebble Pounder Join Date: May 2011 Location: Oskaloosa
Here this is for what your wanting to do: RC Lighting Control Using External Power |
03-08-2013, 01:58 PM | #5 |
thanks pyro
control lights from channel 3 - Similar Threads | ||||
Want to use your third channel too turn lights on and off? | atrain20210 | Electronics | 16 | 01-28-2013 06:17 PM |
Question about 4th channel for lights. | mrtucker80 | Electronics | 4 | 01-01-2013 12:40 AM |
Lights on a wraith with no channel available ?? | bbking9 | Electronics | 3 | 12-29-2011 09:29 AM |
SCX10 TR - how to control stock led lights controller via 4CH TX | Le0Heart | Axial SCX-10 | 9 | 01-13-2011 08:03 PM |
Can I use channel 3 to control two switch? | Froger | Electronics | 9 | 12-11-2008 01:32 PM |
