03-12-2013, 01:56 PM | #1 |
RCC Addict Join Date: Nov 2009 Location: Tulsa
| Cleaning a deans plug?
I have a lipo that has sat in the barn for a week and the deans plug has some corrosion on it. Is there any way to clean the corrosion off so i don't need to put a new connector on it? The corrosion is making it so the battery won't power anything. Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 |
03-12-2013, 02:09 PM | #2 |
Newbie Join Date: Sep 2012 Location: Thornton
| Re: Cleaning a deans plug?
Try steel wool.
03-12-2013, 02:20 PM | #3 |
Will steel wool make the battery spark? Would that ruin the battery? Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 |
03-12-2013, 02:36 PM | #4 |
Moderator Join Date: Jan 2004 Location: chicago
yeah i wouldnt advise steel wool on the deans of a lipo... could try baking soda/water and like a toothpick or something to clean the deans out. im sure some of the more battery smart peeps would know better. |
03-12-2013, 02:46 PM | #5 |
I've used needle files in the past without issue.
03-12-2013, 03:08 PM | #6 |
Rock Crawler Join Date: Nov 2005 Location: Fremont/Newark, California
Scotch Brite pad.....
03-12-2013, 03:21 PM | #7 |
| Re: Cleaning a deans plug? |
03-12-2013, 04:05 PM | #8 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
I think the baking soda and water would also carry current across the solution so I would be careful there as well. Ive used it on 1:1 quite a bit but will typically use scotchbrite or a file to clean out smaller connectors
03-12-2013, 04:39 PM | #9 |
Thanks guys ill give some of these a try Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 |
03-12-2013, 05:25 PM | #10 |
Rock Stacker Join Date: May 2010 Location: Bluefield,WV
I would take some fine sand paper of an emery board and clean them up. I would not use something metal to do this with as you could very easily short out the pack.
03-12-2013, 05:34 PM | #11 |
Newbie Join Date: Jan 2013 Location: newfoundland canada
Scotch pad - red would be best , I find grey not abrasive enough .
03-12-2013, 06:02 PM | #12 |
Do the make scotch brite pads thin enough to get into the plug? Sent from my SAMSUNG-SGH-I717 using Tapatalk 2 |
03-12-2013, 06:08 PM | #13 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
Why not just cut the plug off and solder on a new one, it would of been fixed by now. |
03-16-2013, 02:41 AM | #14 |
03-16-2013, 02:58 AM | #15 |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
03-16-2013, 03:37 AM | #16 |
Cleaning a deans plug? - Similar Threads | ||||
Deans plug? | ThumperK15 | Electronics | 3 | 01-02-2012 06:57 PM |
Which end of a deans plug? | Moparguy | Electronics | 10 | 02-14-2011 08:26 AM |
What Deans Plug On Charger? | Norcal crawler | Electronics | 5 | 06-11-2007 05:42 AM |
