03-13-2013, 04:13 PM | #1 |
Newbie Join Date: Feb 2013 Location: NC
| battery/charger advice
Maybe i should put this in the newb section because i really dont want to get flamed. but i believe in putting things where they belong. i just recently finished building my first RC Crawler. Axial SCX10. i have a HH 35T TorqueMaster Sport motor with a TorqueMaster BRXL ESC. I have a futaba 4pl radio. I have searched and read but i just cannot figure out what to go with as far as a battery and charger. All things batteries confuse me. I understand the differences between NiCd and LiPo to an extent. i understand great caution needs to be used with LiPos. but that's about it. Any useful advice would be greatly appreciated. |
03-13-2013, 04:29 PM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
| Re: battery/charger advice
well what i look for in a pack is to 1 make sure it will fit 2 the discharge rateing 3 weather u can run a 2 cell or thee cell an i do alot of lookin to find the best price as for the charger i choose one that will charge all batts i would use or need to use i bought a onyx 235 lipo charger an my freind had four gens ace batts 5400 mah an a 35 c discharge ratein
03-13-2013, 04:41 PM | #3 |
Quarry Creeper Join Date: Feb 2008 Location: US
Hobbyking.com Their lipos are cheap and work great. Look for a 2 or 3 cell lipo depending on what ESC you run. Keep in mind the less mAh you run, the more C rating you need. C x mA = amps you can safely draw. example: 2000mah battery with a 20-30C rating. 20 x 2 (20 is the C rating 2 is the amp hours or mah drop three decimal places so 2000 becomes 2 amp hours) = 40 amps and 30 x 2 = 60 amps. This means that a 20-30C 2000mah battery can supply 40 amps continuously and up to 60 amps burst (if you are bound up and draw a lot of current). The more amps you can draw the better. As far as a charger, I like the imax B6. They are available on hobbyking as well. Ships from the US and is about $45. Great quality charger for lipos. Cheap and effective. IMAX B6-AC Charger/Discharger 1-6 Cells (GENUINE) (US Warehouse) PM me if I can help you further |
03-13-2013, 04:55 PM | #4 |
thank you both for the input. The "C" rating is something i have been struggling with. i will take a look and see what i can find. Again, thank you both. hibbs, i'll shoot you over a PM if i get to stuck on this. Thanks. |
03-14-2013, 04:07 PM | #5 |
so i ended up going with the Duratrax Onyx 235 AC/DC from tower. needed other stuff and had a coupon. i have read some good reviews from them.
battery/charger advice - Similar Threads | ||||
Battery/Charger ?? NiMH's w/ NiCD Charger ? | 56effie | Electronics | 5 | 10-31-2014 01:23 PM |
Battery and Charger Advice? | BodiBuilt | Axial SCX-10 | 3 | 11-22-2012 09:20 AM |
Going to get the scx 10, need battery/charger advice | Zachary | Electronics | 17 | 05-14-2012 11:54 PM |
Micro Crawler Battery/Charger Advice Needed | sp005 | Losi Micro-Rock Crawler | 14 | 01-29-2010 05:18 PM |
