03-14-2013, 06:16 AM | #1 |
Rock Stacker Join Date: Feb 2013 Location: Bethlehem
| Battery size and run time
Hi , How important is the weight ratio of a lipo to battery run time . What is most important to you on our rig ?? Do you think it is better to have more packs to change out that are smaller ?? We will base this on stock rig a wraith or SCX10 Thank you for any input |
03-14-2013, 07:10 AM | #2 |
| Re: Battery size and run time
Priority list:
- For a comp rig a couple of batteries that last 10 minutes (~1Ah) each is better. - For trail runs more capacity (~4Ah) is better. |
03-14-2013, 07:55 AM | #3 |
Thanks for the reply.. Me and my family are not comping we are just having fun.. We will be building some quality rigs in the future..We are starting with RTR to get into it and learn . I have been reading up as much as I can to learn . We know nothing about the RC Crawling world yet but we will.We own a Archery Pro Shop going on 20 years.so we know everything archery..this new to us My son is 7 He we will be basher for sure for a while. Me and the wife will most likely be into the crawling ..we do allot of outdoors with our jeeps and utv and camping this adds to the list |
03-14-2013, 09:23 AM | #4 |
Rock Crawler Join Date: Jan 2013 Location: San Diego
Scx10 with a 5000mah battery is about an hour runtime for me. I have a 20t motor so it goes pretty fast, and is also why the runtime isn't longer. My dad has a 27t in an scx10 and has about an hour and fifteen minutes with the same battery, even with lights.
03-14-2013, 10:52 AM | #5 |
Quarry Creeper Join Date: May 2010 Location: scotland
i run 5300mah 2s lipo`s and get about 2 21/2 hours with them and of the guys i go crawling with usually get about 3 hours with his 5800mah 2s
03-14-2013, 07:56 PM | #6 |
Thanks for the input what is the weight of you guys batteries compared to a 5000 or is there any ??
03-15-2013, 04:38 AM | #7 |
Weight is roughly the same for batteries in the 3000-6000 mAh range. With a more efficient motor than those mentioned above, like in the 35T-45T range, the battery will last even longer (but the crawler run a bit slower). |
03-15-2013, 08:18 AM | #8 |
| Re: Battery size and run time Thanks for your help and info keep it comming
03-15-2013, 04:03 PM | #9 |
Quarry Creeper Join Date: Apr 2008 Location: PNW
Tekin FXR ESC, 35 turn motor and 5000mah 2S lipo on a Wraith I get nearly 3 hours of run time. I usually end up being done before the battery runs out. One thing to remember that no one has mentioned is that battery size/location also affects the handling of your rig. I went with 22 00 mah lipos for my scx-10 because the 5000 seemed a little heavy and I couldn't quite find a nice location to balance it out for crawling. It handles alot better now with a lighter weight battery, on my Wraith I relocated the battery under the hood for the same effect. Good luck this is a great forum to learn from.
03-15-2013, 05:03 PM | #10 |
Quarry Creeper Join Date: Sep 2012 Location: 01011
I run a 4000 mah 2S thru a Novak Rooster with a HH 45T Torquemaster and get nearly 3 full hrs runtime with the stock gearing. It is setup for turque more than speed but I find that type of setup perfect for a days bashing
03-15-2013, 05:04 PM | #11 |
Thanks for the post..I seen where some have done that sound like a good idea There are so many batteries to choose I guess it is just what ya had luck with What battery are you all using ?? What have the most found to be the best for the money and what vendor or direct you getting it |
03-15-2013, 05:10 PM | #12 |
I have had good luck using Gens Ace brand lipos. They are affordable as a 5000 mah 2s runs around 30 bucks.
03-15-2013, 05:32 PM | #13 |
| Re: Battery size and run time |
03-15-2013, 06:19 PM | #14 |
Rock Crawler Join Date: Mar 2011 Location: hampton
hobbypartz.com hobbyking.com valuehobby.com |
Battery size and run time - Similar Threads | ||||
Battery run time ? | mikey4play | Newbie General | 3 | 10-30-2010 06:45 PM |
battery run time losi battery | perez62682 | Team Losi Comp Crawler | 4 | 03-14-2010 08:22 PM |
battery run time | piper92 | Electronics | 2 | 10-28-2008 12:57 AM |
battery run time? | rider12693 | Electronics | 1 | 09-22-2008 06:55 PM |
Battery Run Time | JasonA | General Crawlers | 2 | 11-14-2006 10:29 AM |
