Thread: Holmes brushed motors
Old 03-18-2013, 05:14 PM   #1
Default Holmes brushed motors
Holmes doesn't seem to have a vendor thread on his brushed motors. Perhaps some of you know. When I bought a Torquemaster Expert, I was told I could upgrade it with a hand-wound armature in the future.
So if I do that, do I wind up with the exact same motor as starting with one of his hand-wounds? By that I mean the can and whatever other pieces are not replaced by the armature change. Obviously I'd probably do brushes just for wear.
Hardline is offline   Reply With Quote
Old 03-18-2013, 05:30 PM   #2
Default Re: Holmes brushed motors
Your only replacing the arm. If you want a better/new can then you would have to buy it separately.
SINister is offline   Reply With Quote
Old 03-18-2013, 05:41 PM   #3
For the quickest answer, I would use the "contact us" link on the HH web page.
It might actually be cheaper to sell your TorqueMaster Expert in the classified section and buy a new Pro.
k7zpj is offline   Reply With Quote
Old 03-18-2013, 09:44 PM   #4
AddictedtoRC1's Avatar
As long as the magnets are still strong in the can you have you'll be just fine with a replacement armature. Check the bearings and make sure they are good also. I'm pretty sure JRH is still using the same can and magnets between the Torquemaster Experts and Pros, but don't hold me to that.
AddictedtoRC1 is offline   Reply With Quote
Old 03-18-2013, 11:13 PM   #5
Yeah, that's the impression I got back then, but wasn't sure I had that right. The motor's low time, doesn't need rebuild. I just want to up the kv.
Old 03-19-2013, 07:14 AM   #6
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
The sport, expert, and pro all share can and magnets. The only differences are in the endbells parts and armature winding on the pro. A pro arm will drop in your sport/ex and make it almost the same.
I have a vendor section you can post in, not just a thread.
JohnRobHolmes is offline   Reply With Quote
Old 03-20-2013, 08:20 AM   #7
Vendors - Holmes Hobbies at RCCrawler.com
lots of threads i there including on the motors
discgolferlee is offline   Reply With Quote
Old 03-21-2013, 10:14 AM   #8
You're right. I was looking on Vendors/Electronics (which also has some Holmes threads). Didn't realize there were threads in two different locations. But I got what I was looking for.
Holmes brushed motors - Similar Threads
New brushed motor paraphernalia and parts at Holmes JohnRobHolmes Holmes Hobbies 28 06-06-2019 10:41 PM
Would you like an affordable Holmes Hobbies brushed Micro ESC? spoo76 Losi Micro-Rock Crawler 35 12-05-2011 04:47 AM
2x Holmes brushed with 1x Mamba Max pro? bpd964 Electronics 3 01-27-2011 04:21 PM
