03-15-2013, 03:44 PM | #1 |
Pebble Pounder Join Date: Dec 2007 Location: canada edmonton alberta
| what esc
Making a BIG jeep, powerwheels size.going to use a 500 watt 24v e scooter motor,no kid ridding in it but will still weight prob 50 lb.What esc can I use? (racing cart drive train) I read that a currie 600w motor is 2600rpm rated current 36 amp
03-16-2013, 06:57 AM | #2 |
| Re: what esc
Are the motors you are looking at brushed or brushless? Are you going to run 24 volt? What battery chemistry will you run (NiCD/NiMH, LiPO, Lead Acid)? Do you want "instant reverse"? The ESC's that may cover "yes" to all above are not very common in RC crawlers. |
03-16-2013, 09:15 AM | #3 |
Quarry Creeper Join Date: Mar 2013 Location: Plymouth
| Re: what esc
If your wanting to run an r/c esc, then the mamba XL2 is gonna be your best bet. It can run 33 volts, all 8g wires and can handle over 80a continuous. The motor it can come with pushes over 10hp on 8s lipo too....
what esc - Similar Threads | ||||
Which ESC Brake/Reverse Type Setting on my Mamba Max ESC? | b00st3d | Venom Creeper | 3 | 01-24-2010 04:34 PM |
older esc anyoen try these LRP RUNNER PLUS ESC W/ REVERSE | rockwerks | Electronics | 9 | 08-16-2006 11:03 PM |
RX pack & ESC, remove the red wire or leave the ESC switch off | BenW | Electronics | 5 | 02-23-2005 06:25 PM |
