Thread: RS Pro W/ Roc412 help
Old 03-17-2013, 02:35 PM   #1
Default RS Pro W/ Roc412 help
I am experiencing an issue when applying throttle to the ESC. The truck sputters a bit then jumps forward. THis happens 90% of the time...
Sometimes it will crawl nice and smooth without issues... I have tried to reseat the sensor cable, checked to make sure the rx is good. nothing is hot or has gotten hot... It's been this way since I took them out of the box.
Can someone please help me diagnose this. I am at a loss...
Thanks!
Fowlboy is offline   Reply With Quote
Old 03-17-2013, 03:36 PM   #2
Default Re: RS Pro W/ Roc412 help
You got a bec? Had the same problem w/the mmp/tekin 13.5 and added a bec it stopped.
hatefulboy is offline   Reply With Quote
Old 03-17-2013, 04:01 PM   #3
Yeah I do!.... I'll get it wired up and hope that fixes the issue... Thank you!
Sent from my iPad using Tapatalk HD
Old 03-18-2013, 09:49 PM   #4
AddictedtoRC1's Avatar
Make sure the ESC is set to either Dual Mode or Sensored Only as well. I have an RS with a Redline 13.5 and it's smooth as butter on startup.
AddictedtoRC1 is offline   Reply With Quote
Old 03-18-2013, 11:09 PM   #5
I have plans to wire up the bec this week just to be sure but I think I may have fixed the issue...
I tried to ensure all sensored & 3s liposettings were enabled;they were and - still didn't fix it.
I tried different rx- didn't fix it
I tried replacing batteries in Tx - didn't fix it
I tried both dm2 and sensored only - didn't fix it
I tried different cutoff voltage settings - didn't fix it
Finally, I decided to save my setup I wanted, then I rolled back to older firmware version then rolled back again to 223 firmware, reloaded saved setup profile and the problem has not returned after a 45min run...
Just wanted to post what fixed the issue for me should someone else have this issue.
If the issue returns, I'll post it up.
Thanks guys!
RS Pro W/ Roc412 help - Similar Threads
FXR with 3100kv ROC412? Fowlboy Electronics 3 02-22-2013 06:25 PM
Gmade and Tekin, roc412 cytogen G-Made Crawlers 0 01-25-2013 02:42 AM
roc412 3100 or pro4 3300 cushdog58 Electronics 4 01-23-2013 06:01 PM
