03-17-2013, 04:34 PM | #1 |
Pebble Pounder Join Date: Dec 2012 Location: Orlando
| Shift servo brown out?
Setup: SCX10 RC4WD 2 speed Futaba 4PK tx Futaba R614FF rx Holmes Hobbies TorqueMaster BR-XL Hitec 37955S HS-7955TG Axial kit steering servo for shifting This works fine and then just doesn't. It's like the Rx stops working - nothing responds. When I unplug the shifter servo it works 100% of the time. I think the shifter servo is stalling, pulling a bunch of amps and browning out the system, but I'm not certain. I noticed that it gets quite hot sometimes. I've double checked the end point adjustments on the shifter servo and all seems fine. Thoughts? Do I need a BEC in this circumstance? I understand the Holmes BR-XL has a built in, but it may not be enough. |
03-17-2013, 06:02 PM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
| Re: Shift servo brown out?
i would try switching out the current shift servo with a diff one. i have had the same prob with a few diff servos doing that.
03-17-2013, 07:03 PM | #3 |
Really sounds like the shift servo is binding mechanically (on the trans) and drawing huge amps. While an external BEC will "fix" the brownout issue, you will fry the servo. I think you need to work on the shift linkage, not adding a BEC since most shift systems are very light loads and only need small servos. |
Tags |
bec, help me!, rc4wd, scx 10 |
Shift servo brown out? - Similar Threads | ||||
Shift servo question... | msd44 | Vaterra Twin Hammers | 20 | 03-01-2013 03:41 PM |
Good shift servo replacement! | Tgreer | Vaterra Twin Hammers | 19 | 02-16-2013 05:43 PM |
Help Setup Gear Shift Servo Please!! | alexchen86 | RC4WD Trail Finder 2 | 4 | 07-20-2012 11:30 PM |
Shift servo? | 09 Screw | Electronics | 5 | 03-01-2011 07:12 PM |
shift servo | 4-linkedWK | Electronics | 3 | 04-12-2008 09:06 PM |
