03-22-2013, 04:59 PM | #1 |
Quarry Creeper Join Date: Sep 2011 Location: The Swamp
| Frankenservo problem....
Sooooooo I'm not really good with electronics....But I am trying to learn. Like the rest of you I have a couple of non-functioning servos laying around. After reading some threads about making servo wiches I had a thought.. " I can either fix or build a winch with all the parts I have laying around." I took a solar 772 case and motor, then applied the circuts from a trx 2075. Suprisingly enough, I got the servo to move and more or less fit into the case. My problem is....... that I don't understand the POT I guess. Is it supossed to tell the servo when to stop rotating and were center is? It seems to center ok, a little twitchy. But when I turn the controler it just keeps on turning. Any thoughts or suggestions? |
03-22-2013, 08:49 PM | #2 |
Rock Stacker Join Date: Feb 2012 Location: Kelso,wa
| Re: Frankenservo problem....
Yes when you modify the servo for winch use, it will keep turning. What good is a winch if you hit the switch and it stops winching after a couple inches? This is normal. You will need a transmitter that has a third channel that is a 3 position switch, winch in, neutral, winch out. If you check out the vendors in here or CKRC, you can buy a circuit to make a winch work with 2 position switch as well. It will also get rid of "winch drift" when in neutral. Hope this helps.
03-23-2013, 06:56 AM | #3 |
What radio are you using? Some are better suited for winch use than others, depends on the options for the channel you're using. I would also check out HeyOK, he makes winch controllers (as well as other items) that work great, even on "factory made" servo winches. [KeyOK is a vendor here on RCC] |
03-23-2013, 06:34 PM | #4 |
Thank you fellas, I think I am going to use a plugin style winch controller for now. It is cheaper than the other options. I do have a question though, when using a plugin style controller do you just straight wire the motor without the circut board? |
03-25-2013, 11:24 AM | #5 | |
| Re: Frankenservo problem.... Quote:
If you are talking about the standard one that I make, yes, it plugs into the receiver and either plugs or solders to the servo motor. The circuit board and pot aren't needed at all on a servo winch as my controller takes care of running the motor. Hope that helps! Al | |
Frankenservo problem.... - Similar Threads | ||||
Problem with Tekin RS system in my LCC, will a BEC fix my problem? | rcboy514 | Electronics | 3 | 01-12-2012 05:55 PM |
Tekin Problem or Radio Problem? | Harvo | Electronics | 8 | 07-30-2010 06:02 AM |
Little bit of a problem, Possibly big problem... | C_Money | Electronics | 11 | 03-08-2010 05:49 PM |
Frankenservo | Duuuuuuuude | Electronics | 3 | 10-18-2009 09:54 AM |
HiTower Servo (AKA Frankenservo) | SeanD | Electronics | 6 | 09-19-2008 08:34 AM |
