03-24-2013, 08:37 AM | #1 |
Newbie Join Date: Feb 2013 Location: selden
| help mamba pro question
everything is new ....including me to this ,I have a tekin reline 13.5 motor ,and the mamba pro esc and castle bec .....I believe everything is wired correctly,,,, when the sensor harnes is plugged in the motor just shutters and wont spin.....when i unplug the sensor harness it works fine ......HELP !!!!
03-24-2013, 08:45 AM | #2 |
Quarry Creeper Join Date: Mar 2009 Location: Grande Prairie, AB, Canada
Make sure your motor wires are hooked up correctly, A-A, B-B, C-C Sent from my GT-I9100 using Tapatalk 2 |
03-24-2013, 09:08 AM | #3 |
RCC Addict Join Date: Oct 2009 Location: In the thinking chair
| Re: help mamba pro question
Double check that the sensor is plugged in all the way, push it in with a small allen. Have you hooked it up to the castlelink to check your settings?
03-24-2013, 09:40 AM | #4 |
Thanks guy`s for the help it was the wires on the motor , I didn`t know they had to be matched .....This forum is awesome and so are you guys for helping ....
03-24-2013, 05:40 PM | #5 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
Check and see if the setting in the Castle program that its on brushless (sensored).
help mamba pro question - Similar Threads | ||||
Dual Mamba Micro Pro question... | maRRtin | Electronics | 5 | 03-12-2012 07:34 AM |
novak 7.5r with mamba max pro question. | obebaldone1 | Electronics | 2 | 11-19-2010 08:02 PM |
mamba max pro question | Boids | Electronics | 13 | 04-30-2010 07:48 AM |
Mamba Max Pro question | wrightcs77 | Electronics | 4 | 01-23-2010 10:00 AM |
