Thread: Frankenservo problem....
Old 03-22-2013, 04:59 PM   #1
Default Frankenservo problem....
Sooooooo I'm not really good with electronics....But I am trying to learn.
Like the rest of you I have a couple of non-functioning servos laying around. After reading some threads about making servo wiches I had a thought..
" I can either fix or build a winch with all the parts I have laying around."
I took a solar 772 case and motor, then applied the circuts from a trx 2075. Suprisingly enough, I got the servo to move and more or less fit into the case.
My problem is....... that I don't understand the POT I guess. Is it supossed to tell the servo when to stop rotating and were center is?
It seems to center ok, a little twitchy. But when I turn the controler it just keeps on turning.
Any thoughts or suggestions?
fla_cracker is offline   Reply With Quote
Old 03-22-2013, 08:49 PM   #2
Default Re: Frankenservo problem....
Yes when you modify the servo for winch use, it will keep turning. What good is a winch if you hit the switch and it stops winching after a couple inches? This is normal. You will need a transmitter that has a third channel that is a 3 position switch, winch in, neutral, winch out. If you check out the vendors in here or CKRC, you can buy a circuit to make a winch work with 2 position switch as well. It will also get rid of "winch drift" when in neutral. Hope this helps.
Ryan87zuk is offline   Reply With Quote
Old 03-23-2013, 06:56 AM   #3
What radio are you using? Some are better suited for winch use than others, depends on the options for the channel you're using.
I would also check out HeyOK, he makes winch controllers (as well as other items) that work great, even on "factory made" servo winches.
[KeyOK is a vendor here on RCC]
Charlie-III is offline   Reply With Quote
Old 03-23-2013, 06:34 PM   #4
Thank you fellas,
I think I am going to use a plugin style winch controller for now. It is cheaper than the other options.
I do have a question though, when using a plugin style controller do you just straight wire the motor without the circut board?
Old 03-25-2013, 11:24 AM   #5
Originally Posted by fla_cracker View Post
Thank you fellas,
Not really sure what you mean by a plugin style controller.
If you are talking about the standard one that I make, yes, it plugs into the receiver and either plugs or solders to the servo motor. The circuit board and pot aren't needed at all on a servo winch as my controller takes care of running the motor.
Hope that helps!
Al
heyok is offline   Reply With Quote
Frankenservo problem.... - Similar Threads
Problem with Tekin RS system in my LCC, will a BEC fix my problem? rcboy514 Electronics 3 01-12-2012 05:55 PM
Tekin Problem or Radio Problem? Harvo Electronics 8 07-30-2010 06:02 AM
Little bit of a problem, Possibly big problem... C_Money Electronics 11 03-08-2010 05:49 PM
Frankenservo Duuuuuuuude Electronics 3 10-18-2009 09:54 AM
HiTower Servo (AKA Frankenservo) SeanD Electronics 6 09-19-2008 08:34 AM
