03-26-2013, 01:48 PM | #1 |
Pebble Pounder Join Date: Mar 2013 Location: london
| futaba 4pl setup
Hi I just boufht a futaba 4pl with a r203gf rx they have already been boind and was used for an hpi e10 now it didnt come with instruction so I was wondering if u all had any setup tips for crawling/trailing/hill climbs the esc has been upgraded to an rc4wd outcry dual motor with fan and the servo is stock I didnt know if that would matter
03-26-2013, 02:17 PM | #2 |
Newbie Join Date: Jan 2013 Location: 808
| Re: futaba 4pl setup
I'm still playing around with my 4pl settings too. I've been using the 4pl for my nitro buggy and scte for quite some time but for my honcho I set a negative exponential on the throttle and reverse and it really helped with the low speed throttle control. Also program your winch to the 3 position switch!
03-26-2013, 04:00 PM | #3 |
1-Welcome to the site. 2-An Internet search will likely yield manuals 3-Why not post a Futaba 4PL question in the "4PL" thread?.... Futaba 4PL Setup, Tips, Tricks & Help 4-Spell check is a great thing.....just saying. What battery are you using? NiCD, NiMH, LiPO? What battery voltage? What rig is this in? (single motor, dual motor/MoA)? Are you "running for fun", trail runs, comps? Last edited by Charlie-III; 03-26-2013 at 04:12 PM. Reason: Edited to add the 4PL question/support link.... |
03-26-2013, 05:53 PM | #4 |
Thanks and im ising 3000mah nimh batteries i run 2 batteries at once I am running 2 27t motors with an rc4wd outcry esc and im using it for trail runs/comps
03-27-2013, 06:39 AM | #5 |
Also willl the futaba bind to the ar3 axial reciever
03-28-2013, 06:18 AM | #6 |
Well thanks for the replies
03-28-2013, 08:59 AM | #7 |
Quarry Creeper Join Date: Sep 2012 Location: middle of nowhere
No need to get insulted due to lack if replies. There is a dedicated topic to your radio that Charlie-III conveniently linked, did you check there? My tapatalk is being uncooperative and won't load the last page of that topic so I don't know if you did or didn't. Sent from my iPhone using autocorrect |
03-28-2013, 11:12 AM | #8 |
| Re: futaba 4pl setup I did not see anything (quick look) that indicates what protocol the AR3 RX uses. Based on this thread... AXIAL AX-3 transmitter & AR-3 receiver miscommunication? it would appear the answer to your question is NO, it will not bind. The GT3B/GT3C is different than a Futaba (yes, they're all 2.4ghz.....still a different protocol). In my house, we have Futaba 2.4ghz radios that use FHSS or FASST. One is a 4PL (my sons radio). |
03-28-2013, 11:38 AM | #9 |
Rock Stacker Join Date: Mar 2013 Location: London
futaba 4pl setup - Similar Threads | ||||
Futaba 4PL Setup, Tips, Tricks & Help | Harley | Electronics | 2217 | 04-27-2023 05:30 PM |
Getting dual fxr esc to setup with futaba 4pl | XJkid93 | Electronics | 7 | 06-18-2012 05:41 AM |
futaba 4pl 2.4 | cossack | Electronics | 1 | 02-02-2011 05:50 AM |
