03-26-2013, 10:21 PM | #1 |
Rock Stacker Join Date: Feb 2013 Location: NY
| Winch control w/ Flysky GT3C ?
Can work? Or Tx needs to be modded? Or only option is the HeyOK controller? Tanx |
03-27-2013, 06:28 AM | #2 |
Rock Crawler Join Date: Mar 2011 Location: hampton
| Re: Winch control w/ Flysky GT3C ?
heyok controller for a 2pos switch losikids hack kit gives you 3 pos channels, cheaper in the long run if you plan to have more than one rig. if your going to buy something to run the winch, and going to have more than one rig, id get the Hack kit. you have to get a controller for each rig if you go with the HeyOK control. nothing wrong with the HeyOK control. biggest factor for me was that i have 4 rigs with winches, i could have bought 4 2pos controls, or just 1 hack kit for my gt3b, i got another rig planed,so id need one more controller. you can run 60 some models off the hacked radio or. go in to 3rd channel EPA and turn it all the way down one direction,left or right, it dont matter, then use servo reverse on ch 3 to control the direction the winch goes,ran mine like this for a few months, works ok, but you can hit the button running and burn the winch up if its set to retract,(did it to a rc4wd winch) or knot the line up if set to spool out(done it many times, pain to untangle) |
03-27-2013, 06:58 AM | #3 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
Hack your gtc3...... Get heyok controller...... Done.
03-27-2013, 09:29 AM | #4 |
RCC Addict Join Date: Jun 2011 Location: Lindsborg
| Re: Winch control w/ Flysky GT3C ? |
03-27-2013, 09:39 AM | #5 |
SuperShafty.com Join Date: Jan 2008 Location: Visalia CA
The controller keeps the servo from drifting. It's a good thing to get the hey ok controller if you run a servo winch
03-27-2013, 09:40 AM | #6 |
03-27-2013, 09:46 AM | #7 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
| Re: Winch control w/ Flysky GT3C ? A fully programmable radio.. any button = any function As an example, I use the steering trim and throttle trim buttons on the top of the radio to control my front and rear winches, and also have the ch3 trim on the handle set up for the front winch (great for single handed use when the other hand is holding the winch line) The ch3 button on the handle being an on/off type is great for switching lights on and off. Regardless, an aftermarket winch controller is a MUST if you have one of the cheap winches. 3racing winch comes with a controller that will stop working the first time it sees any decent load, and the rc4wd controller that comes with the winch cant hold still and will either spool in or out very slowly. They all have their flaws. |
04-12-2013, 10:25 PM | #8 |
Newbie Join Date: Dec 2012 Location: Australia
Can the ch3 button turn lights off/on with out being Hacked? Cheers Red |
04-13-2013, 06:05 AM | #9 | |
| Re: Winch control w/ Flysky GT3C ? Quote:
This will require a lighting controller to be plugged into the receiver. Click the link in my sig if you want to see the lighting controllers I make. | |
04-13-2013, 10:23 PM | #10 |
I wish I had before I brought this http://www.axialracing.com/products/ax24257 with the kit. They are on all the time. Cheers Red |
04-13-2013, 11:05 PM | #11 | |
Rock Crawler Join Date: Oct 2012 Location: Casper
04-14-2013, 11:37 AM | #12 |
RCC Addict Join Date: Jun 2010 Location: fort collins
I have the gt3c hacked, works great with my servo winch but without controler i get drift if i dont set my trim on startup. Getting a controler for mine asap.
04-14-2013, 07:18 PM | #13 |
04-14-2013, 07:31 PM | #14 |
Why wouldn't they work on there own? Just 1 I mean. Cheers Red |
04-14-2013, 07:45 PM | #15 |
They do work on their own but there's no way built in to turn them off. I run a separate controller for a switch, basically.
Winch control w/ Flysky GT3C ? - Similar Threads | ||||
Flysky GT3B and servo winch | Deerhurst | Electronics | 6 | 03-14-2018 04:18 PM |
Flysky GT3C: First Look | losikid | Electronics | 104 | 12-22-2013 12:25 PM |
winch control | djmikeb | Electronics | 4 | 03-07-2011 08:25 PM |
